Owners of aggressive wheel setups
Update everyone i think im going for some volks with some good specs
im looking at 9.5 22offset wiith 245/35/19 and 10.5 22offset 275/35/19
ive already rolled my fenders but lookin at some other cars they stick out more than that in front.
so my question is wtf do you people do? i think ill still have some rubbing issues if i get spacers on them
lowered on eiback springs BTW lookin at coilovers not sure yet
input from people with coilover and slammed as welll
with your current setup, you should be able to get away with 5mm spacers without rubbing. sticking out too much looks retarded because you have generally do a -3 camber or more plus stretched tires which even more retarded because your performance car get much rubber on the ground thus reducing traction. anything more less than a +12 imho is overkill but some people would sacrifice performance, reliability, and longevity over performance.
some good people to ask for advice are deviljon, starve, Fatboy.Yoshi,cheanyoung ....or anyone from San Antonio really..LOL
^^LOL i guess i need to get pics. i measured, its kidna weird one side sits higher than the other
so i have mroe clearance on the right side opposed to left
front will clear 10mm but not sure about rear
ill ask deviljon and them too lol
and 10.5 in rear opposed to 9.5. its pretty sttetched i dont think i want to go as low as 225 and 245 tires.
with spacers? all depends
depends on?
the exact tire (the size on the sidewall is pretty useless)
the exact spacer size
camber front and rear
the bottom line is this - there is no magic answer unless you compare 100% identical setups...same exact tire brand/spec, same exact wheel sizes, same exact height. If you want to know for sure what it will take for these to fit your car you've got basically 1 option...put them on and then see what combo of alignment/body mods is needed. Anything sure of that, and at best, it's an (educated) guess
