Tire Pressure Sensor Activation
Old Sep 17, 2003 | 02:57 PM
Turcoupe's Avatar
Turcoupe
Question Tire Pressure Sensor Activation
Does anyone know how you are supposed to reactivate your tire pressure sensors after taking your wheels on and off? I just replaced my touring wheels and tires with track ones and the TPS screen is coming up blank. The tech at the dealership was trying to use a electronic handheld device that was supposed to re-send the signal. The only problem was that he was using a Nissan Tech Service Bulletin for a "constant TPS light" as directions. I am supposed to come back tomorrow morning becasue a technician will be in that got training for this will be in. I just wanted to see if any of you has went through this already and knows what has to be done...
Old Sep 21, 2003 | 08:32 PM
mwr's Avatar
mwr
If the tire sensor locations had remained the same the system should have worked.
To set the sensors they need to do the following:
ID REGISTRATION WITH TRANSMITTER ACTIVATION TOOL
1. Turn ignition switch "OFF".
2. Connect CONSULT-II and CONSULT-II CONVERTER to data link connector.
NOTE:
If "AIR PRESSURE MONITOR" is not indicated, go to GI-40, "CONSULT-II Data Link Connector (DLC)
Circuit" .
3. Touch “AIR PRESSURE MONITOR”, “WORK SUPPORT” and “ID REGIST”.
4. With the transmitter activation tool (J-45295) pushed against the
front-left transmitter, press the button then keep 5 seconds.
5. Register the IDs in order from FR LH, FR RH, RR RH or RR LH. When ID registration of each wheel has
been completed, a buzzer sounds and hazard warning lamp blinks.
ID REGISTRATION WITHOUT TRANSMITTER ACTIVATION TOOL
NOTE:
Circuit" .
4. Adjust the tire pressure to the values shown in the table below for ID registration, and drive the vehicle at
15 km/h (9.4 MPH) or more for a few minutes.
Tire position Tire pressure kPa (kg/cm2 , psi)
Front – Left 250 (2.5, 36)
Front – Right 230 (2.3, 33)
Rear – Right 210 (2.1, 30)
Rear – Left 190 (1.9, 27)
Old Sep 21, 2003 | 10:09 PM
jake280's Avatar
jake280
NOTE:
Circuit" .
NOTE:
Circuit" .
Hey you seem to know alot about the psi system? can you please help me. i got some new wheels and with out the psi on the new wheels it was fine no psi light flashing. but i decided to add the senors in, and the psi light went flashing. so i just decided to take out the senors and leaving them off the new wheels. after i had taken them out the psi contuined to flash and the reading on the car says 00 which means its reading nothing, so shouldnt the light stop flashing?? Now iam stuck and dont know what to do? if you have any idea please let me know i appreciate it alot. and if i go to the dealer to get them reset how is that going to work? because the senors are aready out of the tire so how extaclly would they reset them?
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
