Volk Wheels Spec.
Old May 4, 2009 | 07:03 PM
~SpInNeY~'s Avatar
~SpInNeY~
Default Volk Wheels Spec.
hope this information will help you guys........
Volk CE28N 18×9.5: 16.76 lbs (7.60 kg)
Volk CE28N 18×10.5: 16.53 lbs (7.50 kg)
Volk CE28N 19×9.5: 20.61 lbs (9.35 kg)
Volk CE28N 19×10.5: 20.50 lbs (9.30 kg)
Volk RE30 18×9.5: 17.86 lbs (8.10 kg)
Volk RE30 18×10.5: 18.85 lbs (8.55 kg)
Volk RE30 19×9.0: 19.84 lbs (9.00 kg)
Volk RE30 19×10.0: 20.39 lbs (9.25 kg)
Volk RE30 19×11.0: 21.38 lbs (9.70 kg)
Volk TE37 18×9.5: 18.65 lbs (8.45 kg)
Volk TE37 18×10.5: 19.40 lbs (8.80 kg)
Volk TE37 19×9.5: 20.94 lbs (9.50 kg)
Volk TE37 19×10.5: 21.82 lbs (9.90 kg)
Volk SF Challenge 19×9.5: 26.79 lbs (12.15 kg)
Volk SF Challenge 19×10.5: 27.67 lbs (12.55 kg)
Volk GTS 19×9.5: 26.79 lbs (12.15 kg)
Volk GTS 19×10.5: 27.67 lbs (12.55 kg)
Volk GTV 19×9.5: 26.57 lbs (12.05 kg)
Volk GTV 19×10.5: 27.45 lbs (12.45 kg)
Nismo LM GT4 18×9.5: 18.51 lbs (8.40 kg)
350Z Stock weights:
Touring v1 18×8.0: 26.56 lbs (12.05 kg)
Track v1 18×8.0: 18.19 lbs (8.25 kg)
Track v1 18×8.5: 18.62 lbs (8.45 kg)
Touring v2 18×8.0: 24.40 lbs (11.05 kg)
Touring v2 18×8.5: 25.80 lbs (11.70 kg)
Track v2 18×9.0: 21.25 lbs (9.65 kg)
Track v2 19×10.0: 29.50 lbs (13.40 kg)
370Z Stock weights:
Sport 19×9.0: 23.20 lbs (10.52 kg)
Sport 19×10.0: 23.80 lbs (10.80 kg)
Old May 4, 2009 | 08:03 PM
FastZ33's Avatar
FastZ33
cool info.
Old May 5, 2009 | 08:22 AM
sry110's Avatar
sry110
Thanks for the info. It's interesting that the weight difference between CE28 19x9.5 and 19x10.5 is 0.11 lbs, while the weight difference between TE37 19x9.5 and 19x10.5 is 0.88 lbs. Also interesting that the 19x9.5 CE28s are actually heavier than the 19x10.5 CE28's. I'll have to look at my set to try to understand why....I'm guessing it has to do with the amount of material around the lug area.
Old May 5, 2009 | 11:09 AM
~SpInNeY~'s Avatar
~SpInNeY~
i have no clue either.....lol.....
Old May 5, 2009 | 03:04 PM
nismonian's Avatar
nismonian
thanx 4 the info
it sux how the gts is heavier than the
stock touring v2
Old May 5, 2009 | 03:15 PM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
Originally Posted by nismonian
thanx 4 the info
stock touring v2
you wouldn't even feel it in the streets
Old May 5, 2009 | 06:23 PM
Gag83's Avatar
Gag83
27 lbs damn lol
Old May 5, 2009 | 07:48 PM
fabcas311's Avatar
fabcas311
whats the weight on the nismo wheels?..(stock nismo)
thanks
Old May 5, 2009 | 08:02 PM
zettahertz's Avatar
zettahertz
^ that'd be the track v2 if i'm not mistaken. 21lbs front, 29lbs rear.
Old May 5, 2009 | 08:15 PM
fabcas311's Avatar
fabcas311
wow!the rear is so heavy!makes me want to get the ce's in 18
Old May 5, 2009 | 10:44 PM
~SpInNeY~'s Avatar
~SpInNeY~
heavy but way more strong structure tho......so still better....
Old May 6, 2009 | 05:55 AM
lgear080's Avatar
lgear080
what about meister's comparatively? they seemed VERY heavy in 19"
when I owned them.
Old May 6, 2009 | 08:43 AM
~SpInNeY~'s Avatar
~SpInNeY~
when I owned them.
donno....but can search it online and see............
Old May 7, 2009 | 05:29 PM
UnFairLady Z's Avatar
UnFairLady Z
what about the gtf??
Old May 9, 2009 | 01:58 PM
~SpInNeY~'s Avatar
~SpInNeY~
same as GTS
Old May 9, 2009 | 02:29 PM
jsin88's Avatar
jsin88
So the forged monoblock(CE/TE/RE) series are the really light ones while the other(GT series) seem to be about as heavy as other comparable brands it seems.
Old May 9, 2009 | 06:11 PM
ohSIXz's Avatar
ohSIXz
We should start the ultimate wheel weight thread!
POST EM UP FOOLZ!!!!!!
^_^
Old May 9, 2009 | 06:32 PM
Sensi09's Avatar
Sensi09
Works Concepts
Thanks for the post.
The 370Z wheels are surprisingly lightweight.
Old May 9, 2009 | 06:51 PM
SuperBlack350z's Avatar
SuperBlack350z
sf challanges and gts wheels are heavy as crap. i didn' tknow they were that heavy.
Old May 11, 2009 | 08:27 AM
sry110's Avatar
sry110
That's actually one of the reasons I bought PIAA Super Rozza's instead of SF Challenges a couple years back. I thought the PIAA's looked better, had a bigger lip, and were just about the same weight as the Volks but at 2/3 of the price.
Maybe the difference is weight distribution though. The Volk SF and GT series have forged outers and cast spokes so maybe the weight is concentrated closer to the center and therefore the inertia is lower than that of a fully-cast wheel with similar weight and dimensions. If that was the case then it might actually take less power the spin the volks up to a give speed in a given period of time.
