I finally did it right. New 18" Wheels Are On!
well, you can still have a little more negative camber and be in factory specs, just fyi. and a little more negative camber in the front will actually help you corner better. mine are at -1.6 which is still factory specs. & i can probably go wider or lower offset in the front.
pics. My wheels are slightly cocked in the garage so i took both sides so you can see that isn't why. I have the above pictures of the front showing the wheels actually out further then i took the rears showing that the rears ARE NOT out further and could use a spacer to match the front.
I think if i put 265's on the front of mine i would have serious fitment issues! there must be a difference in fender spacing.
The only other thing i could think is if the shop didn't order mine in +30 offset. Do they come in another offset that is less?
first 2 are of the rear, showing above and slightly to the side to show they are in a little bit. (like my toes? lol)
see! it's not just me that likes these rims! lol
i don't understand why the rear doesn't have wider lip on them though. There is plenty of room and it would look better but i guess that's how moteigi made them. I probably will end up putting a 10mm spacer on the rear of mine to put them flush with the fenders like my fronts.
nice!
are you talking about mine? mine are bad, they've been collecting dust in the garage along with the road grime from before since I drive it daily. Since i'm tearing the car apart thursday for my super charger install i haven't been much for cleaning it. It'll get the full works once my install is done though!
I don't have a Z yet since im currently selling my 740i, but I think your rear tires are too tall the series is wrong(middle tire number). On staggered wheels like most BMW wheels use a smaller series tire. You should be running 275/35/18's.
Thats because for a BMW the 275/35 would be the correct tire. But for the Z where you need a stagger in height , you need to run the 40 (aspect ratio) in the rear.
