Alignment Spec
Old May 15, 2009 | 07:21 AM
350Speed's Avatar
350Speed
Default Alignment Spec
I just got the alignment done after installing Tein S-Techs springs (already settled). I was trying to compare with OEM specs, but still not sure that my setup will get away with tire wear. Most members here know more than I do about alignment, so I decided to post it up here. Hopefully, someone can tell me that I won't have tire wear issue.
Thanks in advance.
Old May 15, 2009 | 08:04 AM
B5I8's Avatar
B5I8
Here is the factory alignment spec:
https://my350z.com/forum/7209505-post2.html
Old May 15, 2009 | 09:05 AM
scotts300's Avatar
scotts300
I would get that toe closer to 0 - .02. I would also get the camber in the front to match at about 1.5 on each side.
Old May 15, 2009 | 09:52 AM
terrasmak's Avatar
it will work. I suggest a rear camber kit. Yes the rear is in specs but you really don't need/want more that -1.6 on the street.The front is fine, but if you want best tire life put the stock springs back in or buy a civic for a DD
Old May 19, 2009 | 10:30 AM
350Speed's Avatar
350Speed
I just got the alignment done again. I was be able to adjust the rear, but the front remain the same. Here is my current specs.
Front: Camber (-1.6L), (-1.4R)
Caster (8.0L), (8.4R)
Toe (0.03L), (0.06R)
Rear: Camber (-1.5L), (-1.6R)
Toe (0.07L), (0.10R)
Question:
1) Do I really need a camber kit for the front?
2) I'm thinking to cut the spring mount for 1/4in to level the car. Will I have any issue with camber since I was be able to adjust from -2.1 to -1.5?
Thanks.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
