Official Aggressive Wheels & Fat Tires Thread
Old Jul 16, 2012 | 09:53 PM
  #4021
AlexBG's Avatar
AlexBG
I need some help from you guys ... I am not a fan of how low the car sits and dont really like the way the car rides either.
I got a set of Work Basaglio.
I wanna do a fat tire stance on it.
Mods:
Eibach Front and Rear Camber Kit
Hotchkis Front and Rear Sway-bars
Stance GR+ Pro True Coilovers
Fenders: Rears are rolled flat | Fronts have a slight roll on them.
Wheel Specs:
18x10 +14
18x11 +14
Current Tire Spec
225/40
245/40
What tire size/series would you recommend putting on my wheels?
I want the tires to mount fairly square front and rear!
How the car sits at its current state:
Old Jul 16, 2012 | 11:02 PM
  #4022
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Alex, I say go with a 255/40 & 285/40 to start. Could go fatter on the rear with a 305/30.
Play with this calculator; http://www.rimsntires.com/specs.jsp
Old Jul 17, 2012 | 07:23 AM
  #4023
scotts300's Avatar
scotts300
Mods:
Wheel Specs:
18x10 +14
18x11 +14
Current Tire Spec
225/40
245/40
If you want them square, you need the tire as wide - or wider - than the wheel. I suggest a 265-275/35 front with a 285-295/35 rear. Or, if you want to be cool and bold, go 285/30 on the front and 305/30 on the rear.
Old Jul 17, 2012 | 07:27 AM
  #4024
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Old Jul 17, 2012 | 07:55 AM
  #4025
boliviandaddy23's Avatar
boliviandaddy23
ok need your help before i pull the trigger
i have rpf1 f9.5 r10.5 +15 all around...i like the nice fat tire look
i already have 265/35 for the front but for the rear i see alot of you
guys going with 285/35...could i do 295/35 instead? its only a little
difference and i know i will get a little under steer with 285 and 295
...that's question number one...my car is dropped a little less then
1.5inches...so would i have to get my rear fenders rolled? (im guessing
yes) and is camber needed so the wheels wont stick out too much?
can you guys tell me the pros and cons of running nice fat tires?
besides the fact that they are expensive lol got my eye on
bfGoodRidge g-Force T/A KDW 2
Old Jul 17, 2012 | 08:08 AM
  #4026
805350z's Avatar
805350z
[QUOTE=AlexBG;9812647]I need some help from you guys ... I am not a fan of how low the car sits and dont really like the way the car rides either.
Old Jul 17, 2012 | 10:53 AM
  #4027
jarrodh77's Avatar
jarrodh77
You'll need a roll with the 295/35 most likely. No additional camber will be necessary.
Old Jul 17, 2012 | 06:57 PM
  #4028
zswickliffe's Avatar
zswickliffe
Hey guys, actively looking at throwing new wheels on and I can't decide what I want to do. I like the fat look but I don't want to limit my ability to drop in the future. I also want a square setup as I'm told it feels much more natural. So I was looking at some 18x9.5F/R +20 or 18x10F/R +20 - I'm told that the 10" will fit up front at stock height but will they fit on a mild drop (1"-2")? And as far as tire choice, I'd like to run same width F/R with a slight variation in profile to keep VDC happy (40F 45R). What tire width would you recommend/will fit? Sorry for all of the questions and thank you in advance for the help.
Old Jul 17, 2012 | 07:37 PM
  #4029
-Trav-'s Avatar
-Trav-
Youre gonna be real tall in the rear if you do a 40/45 profile. That may even mess up VDC. Many have run square with no vdc issues. If you want to go low Id suggest 275/35 on a 10 all around, with a tire that fits wide. If you stay at stock height however youll have a bit of fender gap with this set.
Old Jul 17, 2012 | 08:09 PM
  #4030
terrasmak's Avatar
10 +20 all around with 275/35 front and 275/40 rear should be a great target for you.
Old Jul 17, 2012 | 08:23 PM
  #4031
-Trav-'s Avatar
-Trav-
Over an inch taller in the back wouldnt affect anything?
Old Jul 17, 2012 | 09:10 PM
  #4032
terrasmak's Avatar
?? You do know the rear tire is supposed to be taller than the front.
Old Jul 17, 2012 | 09:41 PM
  #4033
-Trav-'s Avatar
-Trav-
So youre saying I could roll 285/45/22 out back (theoretically) with stock front and be ok vdc-wise?
It's the larger than normal difference Im questioning, not the fact that it's taller.
Old Jul 18, 2012 | 01:08 AM
  #4034
zswickliffe
It works on a percentage basis as far as I've worked out. I guess the computers look for something like a 3% difference between the speeds of the front and rear. Anything other than that is considered slipping. VDC allows something like 10% of slip as well (which is why some people don't have problems if they're running 0% difference, they still have 7% slip left before it kicks on). At least, that's how I've worked it out.
Old Jul 18, 2012 | 07:28 AM
  #4035
scotts300's Avatar
scotts300
The car in my sig is so low it scrapes the ground lightly on high-G turns. It also has a 10.5" front wheel with a 285/30 tire. If you lower 2" and have a 40-series tire, where do you think you're going to stuff all that tire (height)?
Old Jul 18, 2012 | 08:07 AM
  #4036
terrasmak's Avatar
We have wheel wells with a lot of room, my car is lowered 1 inch (ish) and has been lower in the past. I dont drag hard parts and if i remove my springs and do a travel check, the tire tucks into the wheel well without rubbing.
Old Jul 18, 2012 | 08:42 AM
  #4037
zswickliffe
The example I used for profile was simply that - an example. I have no idea what profile I want to run and I assumed that if I went with 10" wheels, I would need to change to a lower profile tire to make up for it. I just wish there were more specifics on the whole VDC thing - I don't mind driving without it on but I would rather the car function as it should (I know, I'm weird. even if I never used the rear hatch release button, it would bother me if it were broken).
Old Jul 18, 2012 | 09:59 AM
  #4038
Nate08Z's Avatar
Nate08Z
Default Xxr 521s
Hello guys im kind of a newbie still on this site and on my 350z, i curently have xxr 962 19''s on my Z , 235/35r19 fronts nd 255/35r19 rears. Im tired of those rims i want to buy new flat black xxr 521s , but im realy confused , im rolling my fenders and droping my Z about 2'' rear nd 1,5'' front, with bc br coils, i want the new xxrs 18''s , they come in 18x8.5 or 18x10 , i want to go with the widest tire on the rear nd the front dsnt rly matter to me, but i dnt want the tires to be that low pro , i like the beefy tire look, thats why i want 18''s , so should i get 18x.8.5 for the fronts nd 18x10 on the rears , and what tire sizes should i go with? and want any of that streched tire or anything look, i just want it to fit perfect nd run perfect with the widest on the rear and best profile on all 4 , thanks!!!
Old Jul 18, 2012 | 10:10 AM
  #4039
Nate08Z's Avatar
Nate08Z
Default xxr 521
And i dont want any of that streched tire stuff***
Old Jul 20, 2012 | 10:54 AM
  #4040
tioga's Avatar
tioga
Just go with 18x10 on all 4 corners. Really you should do 11 in the back but if you only want 10 then do that on all 4.
I got 18x10 in front with 265 35 and back 11 with a 295 35. With just a roll and i am low and have no problems.
For you just do 265 and for back 285 35
What offset you thinking of?
