Official Aggressive Wheels & Fat Tires Thread
Old Jul 20, 2012 | 01:22 PM
  #4041
danhfvcsd's Avatar
danhfvcsd
Always loved this thread - got the idea for my rims and tyres here!
Rims - Volk CE28N Genesis
Fronts - 19x9.5 +22
Rears - 19x10.5 +22
Tyres - Michelin Pilot Super Sport
Fronts - 265/35/19
Rears - 305/30/19
No VDC Issues, little bit of scraping over bumps at speed on the rear where the rear quarter meets the back of the rear bar tho, even after flaring guards about 13mm and having them rolled...
My weirdest issue is that when i turn left at carpark speeds, the right tyre rubs the inner plastic guard well, but only on the right side??? Hasnt been a major issue for me, so havent looked into it very much yet lol
Not sure how low i am tho, but i'd say its probably pretty close to oem... running BC BR coils (made em an inch shorter than stock shocks before installation) and camber is all oem, or close to it...
Old Jul 20, 2012 | 03:27 PM
  #4042
tbruner's Avatar
tbruner
Originally Posted by Robert_K
Alex, I say go with a 255/40 & 285/40 to start. Could go fatter on the rear with a 305/30.
Play with this calculator; http://www.rimsntires.com/specs.jsp
I cannot figure this calculator out...
Old Jul 20, 2012 | 05:20 PM
  #4043
-Trav-'s Avatar
-Trav-
Put your oem or current wheel size in the left box, and the new size in the right. The calculator will compare the two wheel/tire sizes to give you an idea of how itll fit.
Theres a similar calculator at the top of this page. Look for the big blue link.
Old Jul 20, 2012 | 07:10 PM
  #4044
Nate08Z's Avatar
Nate08Z
Originally Posted by tioga
Just go with 18x10 on all 4 corners. Really you should do 11 in the back but if you only want 10 then do that on all 4.
I got 18x10 in front with 265 35 and back 11 with a 295 35. With just a roll and i am low and have no problems.
For you just do 265 and for back 285 35
What offset you thinking of?
they only make these in 18x8.5 or 18x10, they come in +25 offset i think, cant i go with 40s on the profile tho? i want the wheels a lil beefyer since its gona be 18''s
my car looks like this
want it looking like this
Old Jul 21, 2012 | 12:01 AM
  #4045
danhfvcsd's Avatar
danhfvcsd
Fronts - 19x9.5 +22
Rears - 19x10.5 +22
oops!!! 10.5 rears lol
Old Jul 21, 2012 | 01:50 PM
  #4046
tioga's Avatar
tioga
Those don't look like 40s. But ya your best bet is to use the calculator. Cause also honestly my factory wheels on my 08 Nismo in the rear... 19x10 with 265/35 potenzas look a lot thinner then my new 18x11 with 295/35 bfgoodrich that look a lot taller then I expected. So it has a lot to do with the tire brand you select... some have that fat look some don't.
Old Jul 21, 2012 | 06:50 PM
  #4047
Zhinobi's Avatar
Zhinobi
Old Jul 21, 2012 | 08:35 PM
  #4048
lgear080's Avatar
lgear080
you guys park wayyyyy toooo close... eeek.
Old Jul 21, 2012 | 10:44 PM
  #4049
EmpireDude's Avatar
EmpireDude
Vendor - Former Vendor
Please ignore me if you already knew this, just something I learned the other day on a flight reading motortrend or some car magazine of the like. The 35 actually denotes that the sidewall height is 35% of the tires width. While I agree different brand tires run different sizes for the same advertised size (one brands 285/35 vs. another's) a 265/35 should have a sidewall height of 92.75 mm while a 295/35's should be 103.25...
If you knew this, then please call me a dummy or whatever else! I just figured I'd post up the info in case anyone like me had been misinformed. I thought a 35 sidewall was the same height regardless of width!
Keep posting up the fat tires guys, loving the pics!
Old Jul 22, 2012 | 12:10 AM
  #4050
SE5spd's Avatar
SE5spd
^ interesting autox course. Full road course with cones?
Old Jul 22, 2012 | 03:37 AM
  #4051
taywan's Avatar
taywan
Yea empire- its called the aspect ratio of the first number.
295/30/20
295x.30=88.5 tall
You're not a dummy. A lot of pple don't know that.
Cool shots!!!
Old Jul 22, 2012 | 02:55 PM
  #4052
Esser's Avatar
Esser
295/30/20
295x.30=88.5 tall
Cool shots!!!
Even some tire shops didn't know that here is St. Louis.... I had to explain that it was a percentage. They thought i was high when i told them that.
Old Jul 22, 2012 | 03:14 PM
  #4053
SE5spd's Avatar
SE5spd
lol ^ I'd literally laugh at them.
Old Jul 22, 2012 | 05:14 PM
  #4054
terrasmak's Avatar
Run into that many times too. I believe it has also been mentioned in this thread a few times.
I remember when I was 17 and believed the aspect ratio was 50 and meant 50mm
Old Jul 22, 2012 | 05:42 PM
  #4055
Nate08Z's Avatar
Nate08Z
i didnt knoww this!
Old Jul 22, 2012 | 06:17 PM
  #4056
royblackwood's Avatar
royblackwood
so boring everbody knows what 1 " more offset gives you lets see some 24" or 29" tires something diff ...........God bless Roy
Old Jul 23, 2012 | 06:49 AM
  #4057
scotts300's Avatar
scotts300
295/30/20
295x.30=88.5 tall
Cool shots!!!
Looks like you have the general idea, however, maybe this will clarify a bit, and people won't need "online tire calculators" to figure out the height of tires:
295/30/20: The first number is the (approximate) tire width given by the manufacturer in mm. The second number is - as you've said - the aspect ratio, and the third number is the height of the opening (for the wheel) in inches.
295*.3 = 88.5mm, but there is sidewall on both the top and the bottom of the tire, so the total sidewall is 177mm.
177cm * 1" / 25.4cm = 6.97" of total sidewall.
7" of sidewall + 20" wheel opening = 26.97" tall tire. (Stock 245/45/18 rear is 26.68" tall, so this is a touch taller by about 1%.
Old Jul 23, 2012 | 07:18 AM
  #4058
-Trav-'s Avatar
-Trav-
You make no God damn sense.
Old Jul 23, 2012 | 10:03 PM
  #4059
EmpireDude's Avatar
EmpireDude
It's a banked oval with an infield! Kind of a neat place, it's really neat to drive on the banking.
http://youtu.be/rid9mioqjxg http://youtu.be/EKK5_VrzH2M
295/30/20
295x.30=88.5 tall
Cool shots!!!
Thanks!
295/30/20: The first number is the (approximate) tire width given by the manufacturer in cm. The second number is - as you've said - the aspect ratio, and the third number is the height of the opening (for the wheel) in inches.
295*.3 = 88.5cm, but there is sidewall on both the top and the bottom of the tire, so the total sidewall is 177cm.
perfect, except I believe you mean mm rather than cm I don't mean to come off as a smart ***, just was gonna correct your units and conversion. an 88.5 cm sidewall would be huge
Old Jul 24, 2012 | 09:27 AM
  #4060
scotts300's Avatar
scotts300
Absolutely (the conversion with 25.4mm/inch was correct at least!)
