Official Aggressive Wheels & Fat Tires Thread
Old Jul 28, 2010 | 07:54 PM
  #961
Voboy's Avatar
Voboy
Originally Posted by BEBO'S ZEE
Do you guys roll the front fenders too? Remove the fender liner? I have 255/40 on an 18x8.5 +15 up front and it rubs on the fender every time I turn, what to do besides raise it? I will for now but I like the way it sits as is...
Lowered on F&F coils
http://i708.photobucket.com/albums/w...6/919222f9.jpg
Your tire size is perfectly fine because you have an 18 inch wheel. Going to a 35 series will be too far from OEM sizing. Are you rubbing on the plastic wheel wells or the metal fender? If it's the metal fender I would remove the screw from the top of the fender and drive around for awhile and see if you rub anymore.
*also i hope you adjusted your coilovers correctly. if you messed with the preload that could be why the car can rub so easily too.
Old Jul 28, 2010 | 09:24 PM
  #962
BoomerZ33's Avatar
BoomerZ33
Nexx is right it's the tire. no need to raise.
Old Jul 29, 2010 | 12:12 AM
  #963
BEBO'S ZEE's Avatar
BEBO'S ZEE
Both, I looked at it today and some of the plastic is messed up, nothing big, but I can see a black strip(rubber) on the actual metal part of the fender, it's right where the outer part bends toward the inside.....
Old Jul 29, 2010 | 04:10 AM
  #964
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
Putting these on tonight after I get my rears rolled today, 20x9.5 (+15) on 255 30 20
and 20x10.5 (+15) on 295 25 20
Old Jul 29, 2010 | 08:38 AM
  #965
young Jee(Z)'s Avatar
young Jee(Z)
Originally Posted by zpaaji
^^ wow that a sick looking LS you got there man. where did you buy your front bumper from?
nismo V3 from the local nissan dealer. just under $500 picked up.
specs on the wheels:
19x9.5 +12 (265/30/19)
19x10.5 +12 (275/35/19)
im going to run a 5mm spacer all around as well.
Old Jul 29, 2010 | 05:50 PM
  #966
dkmesa350z's Avatar
dkmesa350z
Nice, how much camber are you running up front? I have a 255/35 on 19" 8.5 +10 and it comes very close to rubbing.
Old Jul 29, 2010 | 06:07 PM
  #967
03threefiftyz's Avatar
03threefiftyz
Base? Your VDC is going to hate you.
Old Jul 29, 2010 | 06:28 PM
  #968
dkmesa350z's Avatar
dkmesa350z
Not necessarily. Rears still taller than fronts. A lot of guys run 255/40 295/35 in 18" applications, and 255/35 295/30 in 19" applications.
Old Jul 29, 2010 | 08:53 PM
  #969
TRYNALIVEPRO
Performance, not a single light, drives nice
right on
crappy cell phone pics, but I'll have better pics up on Saturday with a real camera
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-4.jpg   Official Aggressive Wheels & Fat Tires Thread-3.jpg
Old Jul 29, 2010 | 09:16 PM
  #970
KingBaby's Avatar
KingBaby
Hardest Setting
what the **** are you guys talking about...
it's the fender liner...
remove it take it to a body shop and have them trim or fab up the frame liner thingy that holds the fender in place.
you can bend it with pliers but I recommend a professional
I wish I had pics
245/40-18 F is stock on the nismo and even slam I'm still running it can be done with frame work
EDIT:
i.e. fender roll, hand pull sligthy or use phone book technique easy
O and when I say frame work if you remove the front wheel and remove the liner both pieces(it's two pieces front and back) you'll see a thin piece of rame or whatever you wanna call it poking out. It lines up with the center of the tire....you can hammer it towards you if your facing it...or have a shop remove it...
Old Jul 29, 2010 | 09:32 PM
  #971
Waiz's Avatar
Waiz
TRYNALIVEPRO - Are those SSR SP3's?
Better pics now porfavor
Old Jul 29, 2010 | 09:48 PM
  #972
TRYNALIVEPRO
nope, they are Work XSA-O2C with steplips, my boy who rolled my fenders will do a 'lil photoshoot, so should have real pics to post tomorrow
Old Jul 29, 2010 | 09:49 PM
  #973
Waiz's Avatar
Waiz
Oh wow, I had no idea.
Old Jul 31, 2010 | 02:59 PM
  #974
capo190's Avatar
capo190
Wheels: 19x8.5 front 19x10.5 rear
Tires: vredestein sessanta - 255/35 front ---- 295/30 rear
stock suspension...needs to be lowered.
but i love the meaty look
Old Jul 31, 2010 | 03:31 PM
  #975
SQBassHead's Avatar
SQBassHead
pics from the side please ^^^
Old Jul 31, 2010 | 05:26 PM
  #976
dkmesa350z's Avatar
dkmesa350z
Will look great with a drop! I should have gotten 295/30 - not much shorter than 285/35 and doesn't look too bulgy on a 10.5" wheel like 305s do.
Old Jul 31, 2010 | 07:09 PM
  #977
ExtaZ33's Avatar
ExtaZ33
Old Jul 31, 2010 | 07:41 PM
  #978
dkmesa350z's Avatar
dkmesa350z
Buddy I'm really jealous of your new setup! And SSRs > Works
Old Jul 31, 2010 | 07:55 PM
  #979
ExtaZ33's Avatar
ExtaZ33
Thanks man, your setup is legit too. Good to see you're still in the game. You going to ZNationals this year?
Old Jul 31, 2010 | 08:13 PM
  #980
Waiz's Avatar
Waiz
Your setup is a rolling boner.
Specs?
