Will Acorn replacement lugs work for 18 2003 rims?
Old Jun 10, 2009 | 09:33 PM
TARGET350Z's Avatar
TARGET350Z
Default Will Acorn replacement lugs work for 18 2003 rims?
Trying to figure out the proper replacement lugs for my 350z. I've picked up a replacement set. They are acorn 12x1.25. The look similiar to the original bolts except for the fact that they are shorter in length. I initially thought it would make a difference (ie not flush with wheel). I"ve looked online and the acorn guide does not even have a 350z on it (I knew I shouldn't have taken the sellers word for it). Anyways at this point any help would be much appreciated.
Old Jun 11, 2009 | 04:52 AM
Are these open or closed nut?
Old Jun 11, 2009 | 08:11 AM
TARGET350Z's Avatar
TARGET350Z
Closed nut I believe. They look exactly like the the stock ones. They are just shorter in length. I'm not sure whether that is by function or just by design (maybe to ease with putting them on).
Old Jun 12, 2009 | 01:31 PM
The problem with a short nut is that the inside may bottom out on the stud. Try one. You will be able to tell.
Old Jun 12, 2009 | 02:07 PM
Done Deal DR's Avatar
Done Deal DR
What davidv said. Try it. It will be obvious if it works or doesn't.
Siqcology
Sep 18, 2019 01:45 PM
seagrasser
Oct 11, 2015 03:27 PM
FromGtoZ
Sep 20, 2015 03:41 PM
RWDBajan
Sep 8, 2015 06:25 AM
