Volk 19" TE-37 Insatll questions?
I too replaced my stock 18's with Volk 19" TE-37 this weekend, I had to remove the "stud/screw" from both front plates before the front wheels would go on.
I have one question about the lug nuts...I used the stock lug nuts on all four wheels...I could not use the stock lug wrench because it wouldn't fit in the lug nut holes in the wheel so I had to use a 13/16 inch socket which fit the lug nuts and just barely fit inside the holes...do I need to get different lug nuts and wrench? I was taken totally by surprise with this...please help.
I think I got everything tight and lined up...but do I really?
Frit-z
Frit-z
You should of got some new lugs with the wheel package, I know volk don't come with any but the place you got the wheel should of give you some. Volk also make some lightweight lugs nut if you want them. also you can try to email Brian@racingzoneautohouse.com to see if he have any lugs for you, I know he sell alot of volk rims.
