Quick question need help...
Old Jul 1, 2009 | 07:29 PM
BiggieB15's Avatar
BiggieB15
Default Quick question need help...
My friend just some some Rota's 18x9.5+20 all around for his Z and he is wondering what tire size he should get. He is planning on putting some spacers... What size of spacers and tires should he get? all help is appreciated thank you...
Old Jul 1, 2009 | 08:43 PM
03brembo's Avatar
03brembo
im runnin 275 tires on my factory 18in 8.5 rear wheels (30 or 33 offset?)
with a 25 mm spacer, i had to roll my fender but its sits well. also have tein stechs, sits better
Old Jul 2, 2009 | 07:02 AM
terrasmak's Avatar
How aggressive does he want ? Does he plan to roll fenders ? Does he want to run stretched tires ?
Need to know these things, cause without rolling the standard 275/40 rear tire will start to rub with only a 5mm spacer. The front will start to rub shortly after a 5mm spacer with a 255/40 tire installed.
Old Jul 2, 2009 | 07:37 AM
Allen331's Avatar
Allen331
^ I don't think he'd rub with 275s in the rear for a 9.5 +20 rim. I'm running 285s on a 19x10.5 +23.
The fronts might rub a little if you run 275s up there though IMO
lapham3
Oct 7, 2022 03:15 PM
issyz
Jul 2, 2017 03:04 PM
