275s all around,+12 offset, will it work?
Old Jul 26, 2009 | 08:42 PM
350zDex's Avatar
350zDex
I WANNA RUN 5zigen fno1rc 17x10 +12 ON MY Z TOO IVE GOT RIMS ALREADY BUT ID LOVE THE HAVE THE CONCAVE LOOK!!
heres a z with the 17by10 +12 set-up 27540'S, this guy posted it awhile back on here he said hes on stance coils.
LOOKS SICK I LOVE IT!!
Old Jul 26, 2009 | 09:19 PM
skaterbasist's Avatar
skaterbasist
Not sure how different the Z is from the G in terms of fitment, but I plan to run 245 fronts and 275 rears on a 19x9.5 +7 fronts and 19x10.5 +8 rear. I do have my fenders rolled. I plan to stick with less than -2.5 neg camber.
Old Jul 26, 2009 | 10:46 PM
scotts300's Avatar
scotts300
It looks like one hard turn and it'll rub. I bet the suggestion from Kuah at SPL that this will work is with a lot of front negative camber. It sounds like this car is a DD, so that may not be an ideal situation. The outside portion of my front Hoosiers get glazed from slight rubbing. Another 10mm out will certainly rub without a lot more camber.
Old Jul 27, 2009 | 08:42 AM
solidsnake's Avatar
solidsnake
OK guys I highly appreciate all the responses, I think I have my mind set on 255 front and 275 rear. Rims are still on backorder so I wont be able to post results in a while but when I do I will get a post up.
Old Jul 27, 2009 | 09:44 AM
scotts300's Avatar
scotts300
As an alternative thought, you could get the +25s which we know work, and couple them with a 10 or 15mm spacer to suit your desired look?
Old Jul 27, 2009 | 10:01 AM
jtwolf's Avatar
jtwolf
interesting stuff....I run a square fitment on my DD too.
What the preferred rotation pattern? The book doesn't recommend.
Side to side? Front to back? or X (LF to RR, etc)?
Old Jul 27, 2009 | 11:21 PM
solidsnake's Avatar
solidsnake
That is the reason for the offset choice, I do not want to run any spacers.
Old Jul 29, 2009 | 08:29 PM
QuicksilverZ33's Avatar
QuicksilverZ33
I run a square setup consisting of 275/35/18 tires on 18x10.5 +22 wheels with no spacers and 3 degrees of negative camber in the front and 2.5 in the rear. The car is lowered 1 inch and has no rubbing issues at all inside or out.
I would assume that +12 would rub depending on camber and height.
Old Jul 29, 2009 | 09:00 PM
scotts300's Avatar
scotts300
275/40/17 is actually a little taller than your 275/35/18 set-up. It's slight, but it's something to consider.
Old Oct 12, 2009 | 11:41 PM
dragonball d's Avatar
dragonball d
Originally Posted by Done Deal DR
275's on a 9.5" +12 will rub, you will need to run at least 2-3 degrees of negative camber.
No.
Yes.
Agreed, although I think he should try the set up first and see how it feels. If he feels like it's too tail happy, in situations he doesn't feel it should be, then yes it should be able to be remedied with adjustable sways.
I'm now running a 275 in the front (295 rear). I LOVE the 275 in the front compared to the "standard" 245 I was running (275 rear). I like the steering to have more weight to it, at least for me it's given more confidence in road holding capabilities as well.
question: Can i have -3 front/-2.5 rear camber with all stock suspension(tanabe gf210 spring and hotchikis swaybars only)?
Thank you
Old Oct 13, 2009 | 01:04 AM
solidsnake's Avatar
solidsnake
Mounted pics FTW! 17x10 +12 all around. 255/40 front, 275/40 rear. Sumitomo tires.
Old Oct 13, 2009 | 01:07 AM
solidsnake's Avatar
solidsnake
I do not think anything bigger then 255 upfront would fit, I barely and I mean BARELY have room without spacer so this setup worked out PERFECT! I recommend this setup for DD setup, tires are hella cheap and the wheels are super lightweight.
Old Oct 13, 2009 | 01:48 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Nice!
Old Oct 13, 2009 | 04:40 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Strange. I have 255 up front on my stock NISMO wheels, and have a ton of clearance. Going to get 265 next.
Old Oct 13, 2009 | 06:22 AM
scotts300's Avatar
scotts300
His is a 17x10 front wheel. Yours is 18x9, ya?
Old Oct 13, 2009 | 06:36 AM
terrasmak's Avatar
Thank you
you will get about -1.5 front and -2 rear without front and rear camber arms. Beside, unless you has a track car with R comps, you really don't want more than -2.
Old Oct 13, 2009 | 07:58 AM
CORNELL's Avatar
CORNELL
Sweet! what camber settings did you go with?
Old Oct 13, 2009 | 10:21 AM
  #38
dragonball d
Thank you.
I m thinking about getting 17"x9" or 17"x9.5" with 255 tires for four corners. Z1 star spec or federal 595 rsr.
Old Oct 13, 2009 | 10:34 AM
  #39
terrasmak's Avatar
I'm running -1.8 front and -1.9 rear right now , seems to be about perfect on the track for the tires NT05's.
I just swapped track tires around , now i'm running 17x9 +17 front and 17x9 +7 rear with 275's all around. Track only , i run a standard stagger for street.
To the person mentioning 255 all around, don't. That rear tire is really short and will change the gearing way to much, you WILL need to shift way to often on the track. Do the 275's all around if you don't want a stagger for the track. Also the Z really likes having a wide front tire, its KINDA a heavy car.
Old Oct 13, 2009 | 10:46 AM
  #40
Done Deal DR's Avatar
Done Deal DR
As scotts300 pointed out, this wheel is an inch wider, and (while I don't have the exact figures on hand) I'd venture to say the factory front Nismo wheel is absolutely no where near a +12 offset, thus you don't have rubbing issues...just like I don't have rubbing issues with a 9.5" front with a 275 width tire.
