Need Offset Advice for SSR Wheels...
Old Aug 20, 2009 | 01:12 PM
jdmgee35's Avatar
jdmgee35
Default Need Offset Advice for SSR Wheels...
Any experts can chime in? I'm thinking of upgrading to 20x9.5 and 20x10.5 SSR SP1's in the lowest offset possible that'll fit my akebono bbk's. I don't mind a little stretch and poke, but not too much. I want to have some meat on the tires as well...
Here's the chart for reference:
http://www.ssr-wheels.com/wheels/whe...keepThis=true&
SSR seems to use their own system:
■Super Low Disk: 5/98~5/130
■Normal Disk: 5/98~5/130
■Medium Disk: 5/98~5/130
■Hyper Disk: 5/98~5/130
Can anyone help me out with this? So far, this is what I've heard:
20x9.5 +10 MD
20x10.5 +5 NR
How my car looks now:
Old Aug 20, 2009 | 01:33 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
how much tire do you want? You won't get much tire with those offsets, and you'll be looking at more than just fender rolling (unless you like tons of camber) with those rears
Old Aug 20, 2009 | 02:10 PM
jdmgee35's Avatar
jdmgee35
I would like to keep the 245/275 setup without going too much thinner. Maybe 235/265 is the lowest i'll go. I'm not looking to be too aggressive or stretched, honestly, just something that's flush with the widest lips possible without making my car super cambered out.
What about:
20x9.5 +18 NR
20x10.5 +11 NR
Old Aug 20, 2009 | 02:43 PM
Z1 Performance
Former Sponsor
HD is SSR's code for maximum caliper clearance. Given the size and shape of the factory calipers, I would think that is what you'll need up front (I have not done too many setups with them yet though)
20x9.5 +12 HD
20x10.5 +18 NR - not sure if it clears the rear caliper, might want to check with G37 owners
Old Aug 20, 2009 | 03:08 PM
jdmgee35's Avatar
jdmgee35
20x9.5 +12 HD
R u referring to HP for the hyper disc? Those specs do seem the most reasonable... It's starting to make sense a bit more now. Rear caliper is definitely not that big, so I'm pretty sure NR should work...
Old Aug 20, 2009 | 04:24 PM
Z1 Performance
Former Sponsor
yes sorry, I meant HP
if you need 'em, let us know
Old Aug 20, 2009 | 08:46 PM
HXS's Avatar
HXS
HP for sure up front...
factory brembos might be able to get away with SL in the rear, but might need NR for your akebonos.
liqalu04
Jan 2, 2022 12:58 PM
