spacer stacking?
Old Sep 2, 2009 | 10:39 AM
Twenty4's Avatar
Twenty4
Default spacer stacking?
as some of you know, with work meisters you have to run spacers with extended studs as there are no holes for the stock studs to poke through if you have bolt on spacers. right now im running ichiba 10mm slip ons with extended studs. im wondering if it is safe and/or smart to add another 5mm slip on spacer?
Old Sep 2, 2009 | 10:53 AM
Voboy's Avatar
Voboy
check out the sticky at the top of this forum....
https://my350z.com/forum/wheels-and-...er-thread.html
Old Sep 2, 2009 | 10:57 AM
Twenty4's Avatar
Twenty4
read the whole thing, never really saw this issure adressed
edit* nvm found what your talking about, bad idea. mods please close thanks
Old Sep 2, 2009 | 11:19 AM
travislee's Avatar
travislee
horrible idea. dont be cheap buy some 15mm spacers
Old Sep 2, 2009 | 11:58 AM
GeauxLadyZ's Avatar
GeauxLadyZ
No, it is def NOT a good idea.
If you add another 5mm spacer to another spacer, then your lug bolts are now 5mm shorter than they are supposed to be, and thereby your lug nuts have that much less threads holding the wheel onto the hub.
I believe some say you can run a 5mm slip on spacer without extending your bolts, but i would never do it.
If you want it done the right, and most safe way, get a 15mm spacer with replacement extended studs. Its not like they are too expensive. Then sell your 10's on the board.
Old Sep 2, 2009 | 02:22 PM
TheFarmer's Avatar
TheFarmer
Massive amounts of failure in spacer stacking.
Old Sep 3, 2009 | 12:03 AM
ekidd's Avatar
ekidd
hmmmm
Workshop12
Mar 23, 2020 01:45 PM
