HELP!!! <<<Loose wheel stud>>>
Old Sep 4, 2009 | 04:24 AM
z33allme's Avatar
z33allme
Default HELP!!! <<<Loose wheel stud>>>
So yesterday I was in the process of taking off one of my rear wheels when I get to the last lug and the wheel stud comes loose! Thus not allowing me to take the lug off. Can anyone offer any suggestions as how to ge the lug off?
Here's the reason I was taking the wheel off! I was having a small rubbing issue (only on one fender) so I was gonna give it a small pull.
Attached Thumbnails HELP!!! &lt;&lt;&lt;Loose wheel stud&gt;&gt;&gt;-photo.jpg
Old Sep 4, 2009 | 04:41 AM
quakerroatmeal's Avatar
quakerroatmeal
I had this happen to me I think..I was loosening a lug and it just kept spinning. Lucky for me I used my air compressor and gunned it off and it worked..if anything you might have to bring it to a shop so they can drill/cut the stud/lug off completely..
Old Sep 4, 2009 | 05:04 AM
Here you go: http://www.ehow.com/video_2327338_re...-nut-stud.html
Old Sep 4, 2009 | 05:06 AM
z33allme's Avatar
z33allme
I don't have an air compressor. And I can't drive the car cause the loose stud keeps spinning around and will mess the wheel up/car is to damn low to get it towed. I need and find a local buddy with a compressor.
Old Sep 4, 2009 | 05:09 AM
z33allme's Avatar
z33allme
Originally Posted by davidv
HAHA I saw this video on youtube right before starting this thread. The problem with me is that I still have the wheel on and can't get it off cause that one F ing stud keeps spinning..
Old Sep 4, 2009 | 05:20 AM
Originally Posted by z33allme
HAHA I saw this video on youtube right before starting this thread. The problem with me is that I still have the wheel on and can't get it off the that one F ing stud keeps spinning..
That is a headache. The lug nut is inside the wheel so it is difficult to get to with a nut cracker.
Cold chisel time!
Old Sep 4, 2009 | 07:02 AM
04zee's Avatar
04zee
i had this problem what you can do is take it to a muffler shop or whatever and have them weld the stud from the back onto the hub.
Old Sep 4, 2009 | 07:44 AM
z33allme's Avatar
z33allme
And it's held up fine?
Old Sep 4, 2009 | 09:12 AM
vthao's Avatar
vthao
Probably not. This will just let you get the lug/wheel and tire off. Then you're off to fixing it
Old Sep 4, 2009 | 09:18 AM
Thumbs up
A spot weld may allow you to get the lug nut off. Good idea.
Old Sep 4, 2009 | 12:19 PM
JSia's Avatar
JSia
damn bro i had this happen to me and i had to drill and break the lug nut took a while..
Old Sep 4, 2009 | 12:37 PM
stinky350z's Avatar
stinky350z
sucks to hear that , by the way im selling 45mm ichiba wheel studs very cheap ,
i think if u use a compressor air gun n just keep pressing on it , it might come out , i did that with one of mine , good luck
Old Sep 6, 2009 | 07:46 PM
TeXaSz33's Avatar
TeXaSz33
...Bump...
Old Sep 6, 2009 | 07:53 PM
doncesar's Avatar
doncesar
I had the same problem on 3 of my lug nuts, had to take the car to a metal shop and they melted the studs without damaging my wheels, it was in Laredo TX.
Old Sep 7, 2009 | 04:37 PM
z33allme's Avatar
z33allme
Ok, so Sat a friend and I tried diff things(impact,cold chisel, and a few others). Only to find out none of them worked. So we ended up using a dremel to cut away on the lug. It took awhile a very long time but it worked. I just tapped up the wheels really well and went slowly at it.. Finally broke the lug off and replaced the stud..
Old Sep 7, 2009 | 04:48 PM
quakerroatmeal
Did the wheel take any damage?
Old Sep 7, 2009 | 08:09 PM
z33allme's Avatar
z33allme
No.. No damage to the wheels. I made sure to use plenty of tape and was very very vey carefull
Old Sep 7, 2009 | 08:18 PM
BonesZ33's Avatar
BonesZ33
thank god.. those are my favorite wheels
Obadabot
Jun 18, 2023 11:31 PM
