Rear Tires Wearing In Center
My rear tires (General Exclaim UHP's w/ ~12k miles) are wearing quite a bit more in the center of each tire than they are on the edges. I checked my tire pressure this morning, and I'm at 31 psi. It's colder this morning (about 40 degrees) than it has been yet this summer/fall.
My question is, would it still be okay to back off my tire pressure a little bit to try to get a more even wear, and if so how much?
I realize I don't want to deflate it to the point that the edges of the tires "catch up" with the wear level of the centers, because then I am essentially running with an under-inflated tire, but I would like to at least get it to even out a bit to extend the tire life.
OP, your rear tires are overinflated for the width of the tire. If you have a wider tire with the same wheel diameter, then you actually need less PSI to support the car (PSI = pressure per square inch). It's not a one-to-one relationship, though.
Actually, if your tires wear more on one side than the other, then it's an alignment issue.
350Z_Al
Oct 29, 2020 07:44 PM
usually runs 35psi
