I need some help about the LE37s. Is it ok to run a 19X9.5 34mm offset on the rear of the Z. I really need to know ASAP. If you could help answer this, I would really appreiciate it!
You can, but the 22mm offset would look better. It will push your wheel out more to make it sit more flush with the fender. The spokes will look "deeper" also on the 22mm offset.
