GTR tires and wheels on '04 Track
Old Jan 15, 2010 | 09:26 PM
kennedy's Avatar
kennedy
WHY the F*ck is there a army hummer behind your Z?
Old Jan 15, 2010 | 10:20 PM
350zfan1's Avatar
350zfan1
In the middle of what looks like perfectly quiet neighnorhood ....
Its even up-armord .
Old Jan 15, 2010 | 10:37 PM
JR350z08's Avatar
JR350z08
Originally Posted by 220
but I cannot get traction to keep them from spinning. Even in third gear the rear tires (Falken) break loose between 62 - 86 mph.
If your running your Z like that... why dont you get some Mickey Thompson ET streets... you wont be spinning much. Plus for DR they last pretty damn long.
Old Jan 15, 2010 | 10:45 PM
Barnabas's Avatar
Barnabas
National Z Club President
its not up armored... look at the doors
Old Jan 16, 2010 | 07:29 AM
kennedy's Avatar
kennedy
He is right on it not being armored up but still why is there a hummer there lol. I am more interested in seeing this bad *** military humvee in a quiet neighborhood then the Z lol.
Old Jan 16, 2010 | 07:32 AM
Barnabas's Avatar
Barnabas
im with you kennedy its intriguing and its not an auction one because they remove the turrets for auction and markings as well
Old Jan 16, 2010 | 10:28 AM
marcoyan's Avatar
marcoyan
The GTR tires and wheels I bought just arrived and I tried to mount them on my 2004 Track but the front tires contacted the steering arm and came very close to the Brembro brakes. It looks like a 10mm spacer would work but wanted to see what others had done.
Thanks.
You're right. At least you have to add a 10mm spacer for the front in order to make it work. I just installed mine today...
I may try a 15mm spacer in order to obtain a more aggressive look...
cheers!
Old Jan 16, 2010 | 07:39 PM
TSG-Z's Avatar
TSG-Z
I was gonna ask that same question, that doesnt look like on-post housing neither.
Old Mar 4, 2010 | 03:39 PM
220's Avatar
220
I installed the GTR wheels today with 20mm Kics spacers.
The tires rub a little when I hit bumps but no rubbing when turning. Do I need to stiffen the suspension to keep the tires from rubbing? Any recommendations? People talk about rolling the fenders but what does that actually mean and how is it done?
The HMMWV is for work; I sell machine gun mounts and armored turrets. The HMMWV was modified by Predator Motorsports, 500 hp Duramax conversion, ARB lockers, etc.
Old Mar 4, 2010 | 03:41 PM
Barnabas's Avatar
Barnabas
take it to a body shop and ask them to roll the fenders... around 100 or so to do it.
look at the inside of the front fender... then look at the rear fenders you will see what rolled and non rolled is
Old Mar 4, 2010 | 03:43 PM
BonesZ33's Avatar
BonesZ33
wheels are too big IMO.. looks like a DONK
Old Mar 4, 2010 | 03:58 PM
Alborz11's Avatar
Alborz11
+1
Old Mar 4, 2010 | 04:04 PM
Waiz's Avatar
Waiz
I think you may have too aggressive of a spacer on the wheels, it is making them sit too far outside the fender.
I also think it may be the tires, but I would try the spacers first.
Old Mar 5, 2010 | 08:21 AM
Done Deal DR's Avatar
Done Deal DR
With some adjustments I think it could look great. Spacer might have been a little aggressive in the front, but you may still be able to pull it off. The tires have a tall aspect ratio for being 20's. I run a 30 series in the front and 25 in the rear on my 20's, admittedly I should run 30 series all around though.
Do you have any suspension mods? Might want to roll your fenders and lower it with a quality set of coilovers. That may detract from the "donk" look, but if not new tires with proper sizing for the Z will be in order.
Old Mar 5, 2010 | 09:12 AM
AzuLzed06's Avatar
AzuLzed06
post pix w/o spacer. need smaller tire wall
Old Mar 5, 2010 | 09:43 AM
lgear080's Avatar
lgear080
shoulda stuck to r35 brakes, but what do I know???
Old Mar 5, 2010 | 10:05 AM
Done Deal DR
The front will physically not fit w/o a spacer IIRC (won't clear suspension), it just doesn't necessarily need to be 20mm.
Old Mar 5, 2010 | 11:27 AM
  #38
GeauxLadyZ's Avatar
GeauxLadyZ
Originally Posted by dkmesa350z
so you dropped a couple grand on a set of GT-R wheels without researching fitment/ offsets first?
This.
Btw, i can haz HUMV?
Old Mar 5, 2010 | 11:28 AM
  #39
GeauxLadyZ's Avatar
GeauxLadyZ
Attachment 272811
cheers!
Moar pics of your car, kind sir?
Old Mar 5, 2010 | 11:32 AM
  #40
Entaille's Avatar
Entaille
+1. that is the only Z I've seen where the gtr wheels look awesome.
