Help.. Offset and Tire Gurus..
Having trouble deciding on a tire size... My rims are 18'' 9.5 with +10 offest in front and 0 offset in rear...
Any help appreciated...
What kind of fitment are you aiming for? If you're aiming for an aggressive fitment the first thing to do is sell the 18s and get some wider 19s.
If you're keeping the 18s, you need to start with a 10mm front spacer and a either a 20mm or 25mm rear spacer, depending on how much camber you are going to run.
Well... Im on H&R sport springs and KONI shocks, so im guessing its about 1.2"/1" drop, as for alignment settings... Well i'm not sure because the drop is new to the car and I have not brought it in to be aligned. Also I have a K Sport Rear Camber Kit that is not installed yet....
Thanks
Jordy
Thanks
Jordy
Thanks
Jordy
Thanks
Jordy
I just mounted my new wheels yesterday and they are 18 9.5 +15 all around with 245 40's and 25mm spacers in the rear which rub slightly on bumps. Im gonna put 10 mm spacers in the front
So your saying your running.. 18'' rims 9.5 with -10 and fitting a 245 40 tire if i understand you right? Did you have to roll you fenders? Are you lowered? Or is that what the spacers bring it to? I plan on rolling my fenders..
