wheel help!!!
Old Feb 13, 2010 | 03:16 PM
ZSTONE05's Avatar
ZSTONE05
Default wheel help!!!
i just put a used set of aftermarket rims on my z, now the car is pulling to the right. it drives fine and has no vibration, and the tire psi is good. Y is it pulling to the right?
HELP ME OUT!
Old Feb 13, 2010 | 03:24 PM
Z04's Avatar
Z04
well make up your mind, either it pulls to the right or it drives fine. can't be both. plus pulling is more related to alignment issues
Old Feb 13, 2010 | 03:26 PM
ZSTONE05's Avatar
ZSTONE05
well its pulling and i just got the front end aligned last week.
Old Feb 13, 2010 | 03:32 PM
SatchScream's Avatar
SatchScream
Did you get it aligned before or after you bought the rims?
Old Feb 13, 2010 | 03:56 PM
DavesZ#3's Avatar
DavesZ#3
Same tires as before?
If not, then one of the "new" tires is bad. Probably causing something called "radial pull".
Old Feb 13, 2010 | 04:11 PM
TheFarmer's Avatar
TheFarmer
^What DavesZ#3 said.
Old Feb 14, 2010 | 03:09 AM
Z04's Avatar
Z04
either that or because the wheels were used the wheel might be warped or damaged. OP. did you get the balance checked prior to putting them on?
Obadabot
Jun 18, 2023 11:31 PM
