Will the 2003 Z TPMS work on a 2008 Z?
Old Mar 9, 2010 | 09:46 PM
Z-Lover's Avatar
Z-Lover
Default Will the 2003 Z TPMS work on a 2008 Z?
the part number of TPMS from 2003 is different from those of 2008 tho
so i don't know if the TPMS of 2003 will work on an 2008 Z
please help
thanks...
Old Mar 10, 2010 | 01:25 AM
Z04's Avatar
Z04
they would have to be programmed for the car. plus a different part number is usually a good indicator that it is not the same part
Old Mar 10, 2010 | 03:43 AM
DavesZ#3's Avatar
DavesZ#3
Yes they will work. Keep in mind that 2003 sensors are near the end of the expected battery life (7 years).
Old Mar 10, 2010 | 08:03 AM
FaIRLaDiiZ's Avatar
FaIRLaDiiZ
thanks a lot for the info..
so is it possible to change the battery?
Old Mar 10, 2010 | 08:04 AM
FaIRLaDiiZ's Avatar
FaIRLaDiiZ
do i just take the car to the dealership and let that program the TPMS ? can they program the TPMS while they are inside the wheel? or should i take them out for programming?
thanks
Old Mar 10, 2010 | 08:53 AM
DavesZ#3's Avatar
DavesZ#3
Nope, it's a sealed unit.
thanks
The dealer can reprogram them while they are in the wheels.
Old Mar 10, 2010 | 09:18 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
With that logic, will newer model used TPMS work on a 2003 to avoid battery issues at a fraction of the cost?
Old Mar 10, 2010 | 03:19 PM
DavesZ#3's Avatar
DavesZ#3
yes, if you can find them for a decent price. When mine go out, I plan on looking for some 2007-2008 sensors.
Old Mar 10, 2010 | 03:20 PM
AdvanZ33's Avatar
AdvanZ33
Good to know. Thanks!
Old Apr 7, 2010 | 01:04 PM
Kuhan's Avatar
Kuhan
Dave, are you positive 03 sensors will work on 2008 Z?
The tire installer stripped off one of the 08 tpms while removing from stock wheel and put it in the new wheel.
However, I have a set of 4 03-06 sensors (40700 CD001) that came with the wheels that I'm planning to take one and use it on the new wheel.
So you think this 03-06 sensor will work fine along with other three 08 tpms (40700 JA00C)?
Please help out.
Thank you.
Old Apr 7, 2010 | 03:37 PM
DavesZ#3's Avatar
DavesZ#3
I'm fairly confident that is still a true statement. A year or two ago, two members posted verification that new sensors had worked on older cars and older sensors were working on newer cars. Somewhere around 06 or 07, the part number and appearance of the sensors changed and that's what started the quest to determine if they worked the same as before.
Old Apr 7, 2010 | 03:43 PM
Kuhan's Avatar
Kuhan
Thanks Dave. I'll give it a try this Saturday and will update if it'll work or not.
Old Apr 17, 2010 | 07:43 PM
Kuhan's Avatar
Kuhan
I went to the dealership today to get the tpms learned in.
I have (3) 2008 stock tpms and (1) 03-06 tpms. And all four are now learned and registered. So 03-06 350Z tpms DO work with 07-08 350Z.
Old Apr 18, 2010 | 05:31 AM
DavesZ#3's Avatar
DavesZ#3
Thanks for confirming again.
Old Jun 19, 2010 | 05:02 AM
350z2k3's Avatar
350z2k3
How much did the dealer charge to re-learn the sensors? They quoted me $250 for one new sensor and to re-learn (crazy)
Old Jun 19, 2010 | 05:06 AM
DavesZ#3's Avatar
DavesZ#3
Yes, that's crazy. Buy a used one for $50 and the relearn shouldn't cost you more than $50.
If you are so inclined, you can try to do it yourself....
https://my350z.com/forum/maintenance...ring-tpms.html
burglapfd
Dec 6, 2020 01:04 PM
Stevo Z
Oct 3, 2015 09:14 PM
nanotech
Oct 2, 2015 05:02 AM
