305-30-20 tire fit on a 350z???
Old Apr 5, 2010 | 05:31 AM
2l8ione's Avatar
2l8ione
Default 305-30-20 tire fit on a 350z???
Just woundering if a 305 -30-20 pirelli PZN fit on a piaa 20"x10" rim???
i have 275 on there now looks small for the rim..
Old Apr 5, 2010 | 06:04 AM
Welcome. 275 mm is too small. Go 305 at least.
scotts300's Avatar
scotts300
275-295 is appropriate for a 10" wheel. 305 is out of the recommended size range. It can fit but depends on the offset of your wheel. Many members, myself included, run a 305 tire.
Old Apr 5, 2010 | 06:41 AM
Barnabas's Avatar
Barnabas
National Z Club President
whats the offset on the rim?? like scott said it will fit but be bulged so depending on offset will determine if it will fit in your wheel wheel....
I have 285's on a 10 1/2 rim and its pretty much straight sidewall if it helps any
Old Apr 5, 2010 | 08:48 AM
nismonian's Avatar
nismonian
dont wanna hijack this thread, but will 255/35/19front 295/30/19rear be fine??
running 285/35/19 rears now.
Old Apr 5, 2010 | 09:23 AM
zerafian's Avatar
zerafian
^^yes
To OP: I agree with scott,10" 295s would be perfect
Old Apr 5, 2010 | 09:39 AM
scotts300's Avatar
scotts300
No, it won't be fine. The fronts are taller than the rears, and that will interrupt the VDC-equipped car. Now, if you were asking if it would fit, well that depends on the wheel size (width) and offset. Without this information, an answer is merely speculating or guessing.
Old Apr 5, 2010 | 11:47 AM
phreaktor's Avatar
phreaktor
Design Engineer
Yes, but depending on offsets/widths the rears will rub. Thats what I am running on a 19x10... I have no VDC issues whatsoever...
Old Apr 5, 2010 | 12:37 PM
scotts300's Avatar
scotts300
Fronts are 26.02" tall, rears are 25.97" tall. Maybe that's close enough with some tires to not fuss things up.
Old Apr 5, 2010 | 12:40 PM
2l8ione's Avatar
2l8ione
ok sounds like a 305-30-20 it is sweet thankx guys!!
Old Apr 5, 2010 | 12:48 PM
Barnabas's Avatar
Barnabas
what is your offset?? or are you just making this decision without that information??
Old Apr 5, 2010 | 01:50 PM
scotts300's Avatar
scotts300
??? How did you determine this again? Don't say you haven't been warned! It's also likely that your front tire is taller in height than the rear - VDC won't be happy about that, and that 305 tire is too big for a 10" wheel.
Old Apr 5, 2010 | 03:32 PM
nismonian's Avatar
nismonian
well, the reason i asked about a 295/30/19 is beacuse im running a 285/35 now and it's really beefy (taller than the front) on a 10" wheel, atleast on mine. so a 295/35 i think will look too big
so im guessing a 295/30 will look about the same height as a 255/35....offsets are +21front +23 rear
edit: i have a base so no vdc for me
Old Apr 6, 2010 | 03:18 PM
SQBassHead's Avatar
SQBassHead
i have 305/25/20 on a 10" wheel.
it fits perfect its square with min. - no bulge. it also depends what tires you run since some run smaller than others, with pirelli you should be fine since they run small. i have falkens 452 and its perfect, also i would recommend you go with a 25 series tire instead of 30
Old Jun 20, 2010 | 08:50 PM
Photos of 305 mm tires on the car appreciated.
_koubie_
Sep 20, 2015 06:34 PM
