Tire setup on 18x10.5 all around
So I need some suggestions for tire setup on my rpf1's that are 18x10.5 +15 all around. From searching it seems that most are running a 265/35/18 all around. I am only lowered on eibach prokits so i want some tires that will close up the gap if possible. Any feedback would be helpful. Thanks in advance.
I have Advan rims that are 18x10 +19 offset. I run 265/40/18 up front and it doesn't touch the fender, but if I hit a dip and it fully compresses, it does touch the wheel well liner by 1 or 2mm. The rear tires I am running 285/40/18 and had to cut the fender lip(I actually completely cut the inside lip off versus rolling). With that done, I I have about 10mm of fender clearance on full tucked compression.
I ride on Hotckis springs, (15mm front, 19mm rear drop), Rear camber set at 1.0 degree negative, 0.08 degree positive toe.
With your 15mm offset, you can clear 255/40/18 front, and 275/40/18 rear no problem. Though I suggest rolling your rear finder inside because that lip intrudes about 3/4".
True, it does look strange with the rears having a more "fuller" appearance. The reason why I didn't square it was because I kept my original tires upon switching rims. My rear tires are basically bald right now so I will go back to squaring out the tires and running hubcentric spacers in the back to fill it out better.
If you are going to run that close of a tire size just make it the same on all 4 so then you can rotate them. you will notice almost no difference in running a 265 in the front and a 275 rear. on an 18x10.5 i would run an 275/40
