19x11 +18 ??
Old May 23, 2010 | 12:29 AM
TehkMob's Avatar
TehkMob
Default 19x11 +18 ??
19x11 +18 Will it clear the knuckle on the front?
Old May 23, 2010 | 01:02 AM
terrasmak's Avatar
Doubt it, a 9.5 +35 has minimal clearance , and that wheels is 2mm in more. YOu may need a 3mm shim
Old May 23, 2010 | 07:33 AM
TehkMob's Avatar
TehkMob
^^ Does camber come into play as well.. My car is dropped on coils, and its pretty low. like if i hit a nasty bump my tire will hit the top of my wheel well in the front. so you think this is somethin i can remedy with a 5mm spacer with minimal clearance issues in the front fender? I do plan on running the same size wheel out back with a 15 mm spacer as well. So it would end up +13 in front and +3 in the rear with 265 all the way around. Do you see any other fitment issues I should look into?
Thanks, Dustin
Old May 23, 2010 | 12:29 PM
terrasmak's Avatar
Camber won't do a thing, its the fixed upright on the spindle that is close. You may not even need a spacer, just be prepaired to get one. Best suggestion is to just but a 19x10 for the front, thats the widest wheel you can fit without running stupid camber and major stretch tires.
Old May 23, 2010 | 08:27 PM
TehkMob's Avatar
TehkMob
terrasmak,
Thanks for all the input! very helpful.
tm9293
Wheels Tires
Sep 11, 2015 02:45 PM
Andy@Performance
Apr 14, 2007 09:52 PM
Z33_SPL
Dec 20, 2006 11:40 AM
vroom350z
Southern California
Nov 4, 2006 12:43 AM
smellslikecurry
Jun 16, 2005 09:40 AM
