spacer size.. help please!
Old May 23, 2010 | 07:06 AM
zaperroni's Avatar
zaperroni
Default spacer size.. help please!
Hi, I have rims with these dimensions:
19x8.5 45mm offset
19x9.5 45mm offset
what size wheel spacer would I need to make the wheel flush looking with the fender?
thanks!
Old May 23, 2010 | 09:20 AM
ComeBack's Avatar
ComeBack
19x8.5 45mm offset
19x9.5 45mm offset
thanks!
Umm why would you get such high offset of wheel?? Well to get them to even fit you would probably need a 15mm all around. To make it flush it really depends on tire size but a 30mm or 35mm should maybe do the trick. I would sell those and get a set with a correct offset to fit your car.
Old May 23, 2010 | 09:50 AM
Black Z Eddie's Avatar
Black Z Eddie
I agree, you should get new wheels. Those offsets are way offset. Probably, as a rule of thumb, wheels shouldn't have greater than +30 (for example yours is 45). But, if you must, the below link may help in measuring.
https://my350z.com/forum/6680674-post7.html
The only thing is, it only goes to +25 (spacer size).
Old May 23, 2010 | 10:25 AM
Do you have a ruler? Then measure how far you want to move the tires.
Old May 23, 2010 | 12:40 PM
terrasmak's Avatar
I would get wheel spacers that include new wheels. Sell your wheels to an S2K guy or something
Old May 25, 2010 | 05:16 AM
reverse's Avatar
reverse
they won't be flush with any spacer with that wheel offset. u would need at least a 40 mm spacer & i think 30 is the max they make. so yeah, u would need at least a 30 to bring u somewhat close.
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
