Proper tire pressure for 275/40 and 245/40 on 18s?
Old Nov 5, 2003 | 02:43 PM
teh215's Avatar
teh215
Default Proper tire pressure for 275/40 and 245/40 on 18s?
I just had a set of Falken FK451s, 245/40/18 & 275/40/18, mounted on 18X8.5 and 18x9.5 wheels and the tire shop inflated the tires to "51 psi per the tire". This seems way to high to me. What pressure should I be running?
Old Nov 5, 2003 | 02:46 PM
Audito350Z's Avatar
Audito350Z
try 34 or 36 front and rear....
Old Nov 5, 2003 | 03:21 PM
johnlotusboy's Avatar
johnlotusboy
From the load range of I'd try 35-36psi front and I'd try 31-32psi rear, and tune from there.
Old Nov 5, 2003 | 06:08 PM
lowrider's Avatar
lowrider
My 18" Nismos came with a little instruction sheet. As far as tire pressure it says:
"If the vehicle is factory installed with 18" tires, see vehicle tire placard for the recommended COLD tire air pressure"
"If replacing 17" tires, adjust the COLD tire air pressure for the new 18" tire at 35psi on the front and 35psi on the rear positions."
So - 35lbs it is for me.
Lou
Old Nov 5, 2003 | 06:16 PM
droideka's Avatar
droideka
Holy sh*t! What kind of inbred morons did you take your wheels to? 51 PSI is the MAX. Check and make sure they properly mounted the tires per the rotation arrows.
Old Nov 6, 2003 | 01:11 AM
teh215's Avatar
teh215
Thanls everyone. Factory pressures are what I thought but, I wanted to ask around. I actualy had them mounted at the Goodyear tire place just down the road. Trust me, I checked everything, especially the rotation direction of the tires. The only thing that I have left to check is that they moved the right fron TPS to the new right front wheel, etc.
Thanks again!
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
