Please help me pick a tire size
Old Jun 8, 2010 | 01:18 PM
ChrisNelson's Avatar
ChrisNelson
Default Please help me pick a tire size
I just ordered a new set of four 19x9.5 wheels with 20mm offset on all four corners. The wheels are identical and I need some tires that will look good. I'm not sure if they should be identical sizes or not. Maybe the rear should be bigger to give it a more aggressive look?
The car is an '05 and it's not lowered - I don't plan on lowering it.
Thanks for the input!!
Old Jun 8, 2010 | 02:12 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I honestly think a 275 is too wide for a 9.5" rim. I would personally do 245/35 265/35.
Old Jun 8, 2010 | 02:14 PM
Barnabas's Avatar
Barnabas
National Z Club President
what kind of driving?? budget?? expected performance?? why did you do a square setup??
Old Jun 8, 2010 | 03:16 PM
procustomize's Avatar
procustomize
go with hankook V12 you can't go wrong. Cheap, high performance, better ride comfort.
Old Jun 8, 2010 | 03:30 PM
NismoZ_840's Avatar
NismoZ_840
275 is fine on a 9.5" from a wheel fitment standpoint (max 285 per Tirerack tire spec charts). I think 275 shouldn't rub the fenders at et20 theorhetically as you can put 295/315 on OEM 18/19 et30 w/ stock suspension and no rub, it will be close. I'm sure someone can validate from actual experience though. Suspension clearance should not be an issue as I'm running front 275 et30 (35et + 5mm spacer, 35et is only ~1-2mm from rubbing the suspension). Don't forget to validate rear height 0-3% taller than front for VDC.
Old Jun 8, 2010 | 04:07 PM
terrasmak's Avatar
255/35 front and 275/35 rear is the common setup
Old Jun 8, 2010 | 04:22 PM
Spike100's Avatar
Spike100
Hi Chris, You are in Bemidji, Minnesota so you will run your car on two lane highways built in swampy areas that often have irregular surfaces. There is plenty of rain there so you will occasionally be on wet roadways.
In that type of environment, I think you are better off with a staggered setup that provides some amount of under-steer.
A couple of possibilities with your new wheels:
1) 245/35-19” Front with 275/35-19” Rear
2) 255/35-19” Front with 285/35-19” Rear
Your wheels are square, but if you go with tires having the same width front and rear, your car will have neutral steer. That can get tricky on wet roadways with irregular surfaces.
--Spike
Old Jun 8, 2010 | 06:06 PM
No need to figure it out when it has been done for you. Look at the Track 18/19" v.2 wheels and tires.
Old Jun 9, 2010 | 01:59 PM
scotts300's Avatar
scotts300
A 315 has no business going on the OEM 19x10 wheel.
--Spike
I agree, and would vote for #2 with gun-to-head. Maybe even a 265 front since a 255 on a 9.5 is going to produce a little stretch. I don't like how 255s look on my 9s, let alone a 265 (of course this is VERY tire dependent).
Old Jun 9, 2010 | 05:00 PM
Spike100's Avatar
Spike100
^^ I agree. 265mm wide tires are a good pick for 9.5” wide front wheels.
Although a 245 or 255 wide tire is within specifications for a 9.5” wide wheel, that width tire (especially the 245mm tire) will be stretched.
In Bemidji, Minnesota, there are no issues parking far enough away from curbs to avoid scraping nice wheels. In fact because of the snowfall in Bemidji, the streets downtown are very crowned and the curbs are very high. It isn’t so much curb-rash you need to worry about, but actually scraping the side of your car that can be a concern.
--Spike
Old Jul 22, 2010 | 06:52 PM
BigDaddyZ's Avatar
BigDaddyZ
I was considering doing the same squared set up on my '03 except with a 25mm offset on the wheels. However, I have been told that this set up would either not look right, drive right, and/or fit correctly. Everything is Base line stock and I as well do not plan on lowering the car, at least anytime soon. Im curious on how this turned out for Chris, anyone know? I guess what I am trying to find out is if I should stay away from this setup regardless on how much I like the wheels. I also was curious on the tire size selection below. I am trying to stay within the 0-3% range so I can stay clear of the slip issue. Would the listed tire size (#2) below be ideal for the 20mm offset for these tires too? I show the spec difference from the OEM as follows; please correct me if im wrong in thinking i will not have any slip issues.
(F) 265/35/19 - has a 1.7% difference with a circum. of 82.63
(R) 275/35/19 - has a 1.2% difference with a circum. of 83.50
Thanks,
Aric
Old Jul 25, 2010 | 08:04 PM
ChrisNelson
This is how it turned out:
Old Jul 26, 2010 | 06:40 PM
Spike100's Avatar
Spike100
^^ Looks good Chris. I really like the black spokes with the polished rim... and the flush tire fitment (although a slight drop would improve this).
Any reason you decide not to post the specifications with your pics?
--Spike
Old Jul 26, 2010 | 06:45 PM
Ruthless18x's Avatar
Ruthless18x
So what sizes are those ^
Are you the dude that made the thread asking if those wheels looked like Mustang wheels, like two months ago?
Old Jul 26, 2010 | 07:19 PM
=Cerberus='s Avatar
=Cerberus=
I noticed you were in Bemidji MN, I will have to keep an eye out next time I am out there. My company is installing the seating at the event center and I should be out there in a couple of weeks.
Old Jul 27, 2010 | 08:07 PM
ChrisNelson
Sorry guys, not trying to keep any secrets, what's the point of that? haha. Just forgetful.
I did not ask if these where Mustang wheels...?
Specs: Front: 245-35-19; Rear: 275-35-19
They are Hankook Ventus V12 tires
Old Jul 28, 2010 | 04:11 AM
Barnabas's Avatar
Barnabas
love the v12 tires and def get a drop!!
Old Jul 28, 2010 | 04:25 AM
PikeZ_350's Avatar
PikeZ_350
You realize that 265-series tires are expensive as fawk right? Not to mention there aren't many options...
Old Jul 28, 2010 | 04:54 AM
BoomerZ33's Avatar
BoomerZ33
tires came out good even with the basic setup 245/275. not too fond of the crooked nismo decal tho
Old Jul 28, 2010 | 05:00 AM
PikeZ_350's Avatar
PikeZ_350
245/275 is a common setup...Why don't you want to lower your car? jw..
