shitty pic. xxr 527 18x8.75 +20 all around 20mm spacers in back 10 mm in the front. 240-40-18 and 245-45-18. plan on getting 255-40/ 275-40... i like the fat looking set up.
Probably going to pull the trigger on these gold 521's soon. going to be getting 18x10 +25 all around. would 265/35/18 and 285/35/18 be about right? need some advice from some wheel/tire gurus if possible!
275 rear is not fat by anymeans
Also 11" wheel with 255s look hideous. Looks like euro trash
275 on a 8.75 if a fat look. not in general like a 305.
8.75 because i dont like the stretched look..i consider my 245-40 on my 8.75 stretched looking. IMO. 275's on a 10 wide wheel have about the same fit as a 245 on a 8.75 wheel. i dont like the look of it.
so 275 on a 8.75 wheel will give the the look i want. if i ran 10" wide wheels i would probably run 305+ to get the look i want. but thats my personal preference. btw, i would run 10" wide wheels and 305 tires if i could afford the upkeep and initial cost of tires/wheels etc.
526's in gloss black 18x9 all corners +25 offset.........Will need to get 15mm or 20mm spacers for rears and eventually lower it in future. Better pix coming soon.
why didn't you at least staggered it??! or if you want the square setup why not go 10.5 all around!
