19x10.5 +15 all around?
Old Jun 16, 2010 | 09:51 PM
JjL's Avatar
JjL
Default 19x10.5 +15 all around?
I'm on the fence before I order some wheels. I want to run 10.5 all around but I'm more concerned about front fitment and how wide of tire I can run at the front or should I play it safe and order 19x9.5 +12 for the fronts.
The goal is to run 10.5 wides for the fronts w/ either 255/35 or 275/35 as the front tires without touching any body panels and just have slight camber nothing extreme.
any info would be great, thanks!
Old Jun 16, 2010 | 11:05 PM
topjake10's Avatar
topjake10
I had 19x10 +20 on all four corners with 275 35's and the fronts stuck out a bit too far for my liking, but to each is own. Have you already bought them?
Old Jun 16, 2010 | 11:08 PM
BiggieB15's Avatar
BiggieB15
It all depends on how low your car is...post pictures
Old Jun 16, 2010 | 11:34 PM
JjL's Avatar
JjL
the jlines are 18's on coils. I wouldn't want to go any lower then that since I already bottom out daily driving.
I havent ordered them yet but I would want to soon since it would take 1-3 weeks to get from rays and 4-6 weeks to get get it in my hands but I can wait since I have a set of 18x9.5 +12 and 18x10.5 +15 coming in soon. Worst case scenario i'll test fit the 10.5 when they come and see how it is and goes from there.
Old Jun 17, 2010 | 01:29 AM
sdZ33's Avatar
sdZ33
I'm running a 20x10.5 +24 in the front and I bearly clear the suspension... I'm also lowered 1"... I think you'll be fine with a 19x10.5 +15... A 275 tire will be a slight stretch so that gives you more room to clear the fender... But if your going to a square setup, I think the front will poke out more than the rear... I could be wrong tho...
Old Jun 17, 2010 | 03:33 AM
3 mm is going to make a significant difference?
azndoc
Wheels Tires
Oct 10, 2015 02:59 PM
tm9293
Wheels Tires
Sep 11, 2015 02:45 PM
Juztin
Vendor Wanted
Sep 8, 2015 10:02 AM
