Blondegirl Needs Help :)
Old Jun 23, 2010 | 01:04 PM
F34RL355's Avatar
F34RL355
^+1
Old Jun 23, 2010 | 01:21 PM
Hexxus's Avatar
Hexxus
Pics in my inbox in 15 minutes or else...
Or else...
Old Jun 23, 2010 | 01:28 PM
Done Deal DR's Avatar
Done Deal DR
..... What? Is this the new way of getting pics - actually help them?
Or else...
Old Jun 23, 2010 | 01:33 PM
huyrua's Avatar
huyrua
LOL, J/K on the pics.....I was hoping that she would feel sorry and pm me her pics.
Old Jun 23, 2010 | 01:43 PM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by Blondegirl66
I just put new wheels and tires on my '08 350z (on Monday). I was told the sensors from my stock wheels were taken off and put on the new wheels. The TPMS light (!) blinks when I start the car and then stays solid. I had the sensors checked by NTB and was told the sensors are fine but that the transmitter isn't receiving the signal?
Do I need to have the system recalibrated?
It might be helpful to know I had stock 18's and put 20x8.5's on the front and 20x10's on the back. I don't know if that matters. Any insight is greatly appreciated!!!
Does the light start blinking when you start the car or when you start driving?
Have you checked your air pressure in each tire?
Old Jun 23, 2010 | 01:49 PM
surfcity40's Avatar
surfcity40
LOL on pic requests in exchange for help Very funny. I've searched this site for all TMPS/ wheels related questions and haven't found anything on the TPMS light blinking and then staying on.
Thanks again for any insight into what's going on and how to fix it!
every 60 miles or so it goes off if it ain't right....something like that...but I'm going back to like 05/06. Just shut the car off and turn it back on.
Old Jun 23, 2010 | 01:52 PM
DavesZ#3's Avatar
DavesZ#3
Since you have an '08, you're probably still under warranty so I'd definitely take it back to the dealer. I suspect that NTB broke one of the sensors.
According to your owners manual, a blinking light is a sign of a malfunction.
TPMS malfunction:
If the TPMS is not functioning properly, the low
tire pressure warning light will flash for approximately
1 minute when the ignition switch is
turned ON. The light will remain on after the 1
minute. Have the system checked by a NISSAN
dealer.
For additional information, see “Tire pressure
monitoring system (TPMS)” in the “5. Starting
and driving” section.
Since the only thing they touched was the wheels and the sensors, they (NTB) are the likely culprit for the problem.
Old Jun 23, 2010 | 02:15 PM
Chebosto's Avatar
Chebosto
Old Jun 23, 2010 | 02:19 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Originally Posted by My350z.com Usorz Manual
No pics = malfunction
No sis **** pics = ban
According to the My350z.com manual, no pics is a sign of malfunction.
Old Jun 23, 2010 | 02:38 PM
Blondegirl66's Avatar
Blondegirl66
To Nissan I shall go. Based on what I'm reading here I really think the system just needs to be recalibrated for the new wheels. Oh, and the tech said he wouldn't charge me.
Surprise surprise
Thanks for all the info!
Old Jun 23, 2010 | 02:49 PM
Waiz's Avatar
Waiz
Originally Posted by Chebosto
This
Old Jun 23, 2010 | 02:50 PM
DavesZ#3's Avatar
DavesZ#3
I'm not thinking re-calibration. Resetting them might work but the symptoms don't indicate that to be the problem. Usually, once you start driving the car, if the sensor is not being picked up, after about 30-45 minutes the warning light (!) will go off. That happens when the system is working fine, but after the preset period of time it doesn't detect one or more of the sensors. BTW - the sensors don't start transmitting until you're going about 20 mph.
In your case, the warning is coming on after starting the car. You're not even driving yet so there's no reason for the system to expect any signal from a sensor. Something else is wrong. I don't see how they could have messed up the system by swapping wheels. It all may be coincidence.
good luck with the dealer.
Old Jun 23, 2010 | 02:51 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Originally Posted by blondegirl66
i just put new wheels and tires on my '08 350z (on monday). I was told the sensors from my stock wheels were taken off and put on the new wheels. The tpms light (!) blinks when i start the car and then stays solid. I had the sensors checked by ntb and was told the sensors are fine but that the transmitter isn't receiving the signal?
Do i need to have the system recalibrated?
It might be helpful to know i had stock 18's and put 20x8.5's on the front and 20x10's on the back. I don't know if that matters. Any insight is greatly appreciated!!!
sammich or stfu!!!!!!!!!!!!!
Old Jun 23, 2010 | 03:05 PM
DavesZ#3's Avatar
DavesZ#3
Ruh roh. Hraes found it.
Old Jun 23, 2010 | 03:16 PM
Done Deal DR
Old Jun 23, 2010 | 03:31 PM
Done Deal DR
Old Jun 23, 2010 | 03:36 PM
DavesZ#3's Avatar
DavesZ#3
Guys - let's keep it civilized. At least until we get the pics.
Old Jun 23, 2010 | 04:04 PM
  #38
GeauxLadyZ's Avatar
GeauxLadyZ
I have taken the liberty to provide pic of what OP should look like:
^This.
Old Jun 23, 2010 | 04:08 PM
  #39
DavesZ#3's Avatar
DavesZ#3
Old Jun 23, 2010 | 04:23 PM
  #40
sumroffun's Avatar
sumroffun
Default same issue
with no need to send pics i will give advice from my experience, I have taken my to the dealership with no luck they don't have anything to program your car with when you go with different tires. my nissan as well as yours will think its losing traction when its not and i haven't found ny way to fix this issue the one thing left i haven't tried is to get a programmer to tell your computer in your car that it is running 20's not 18's but not sure if the programmers do that.... or who ever set your tires jacked them sensors up and they need replaced they are or can be sensitive when taken off or messed with hope this helps
