Tire suggestions?
Old Jul 12, 2010 | 02:30 PM
danielmarc1983's Avatar
danielmarc1983
Default Tire suggestions?
Hey guys, I just got a set of SSR Type F for my Z. They're:
18x8.5 +30
18x9.5 +22
What size tires should I get? I don't want to have any stretch if I can avoid it. Also taking suggestions for brands. These are for the summer only, so not really looking at all season. And I want to lower my car moderately, maybe 2-3 inches, can anyone recommend springs?
Thanks for all the help.
Old Jul 12, 2010 | 02:41 PM
The 2007 Nismo runs
Front
Offset: +30mm
Weight: 21 lbs 4 oz
Tire: Bridgestone RE050A 245/40/18
There is your starting point.
Old Jul 12, 2010 | 04:44 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Front: 245/40/18
Rear: 275/40/18
Spacers:
Front: 25-30mm
Rear: 15-20mm
Awesome wheels, not so awesome offset choices.
Old Jul 13, 2010 | 09:01 AM
danielmarc1983
Thank you both. It's my first set of wheels. I got a sick deal on them, otherwise I was holding out for advan super 2s.
Old Jul 13, 2010 | 09:20 AM
terrasmak's Avatar
Standard sizing, 245/40 and 275/40 is where its at.
Old Jul 13, 2010 | 05:56 PM
danielmarc1983
will the 275 be too wide a tire for my 9.5 rear?
Old Jul 13, 2010 | 05:57 PM
03threefiftyz's Avatar
03threefiftyz
^No.
Old Jul 14, 2010 | 04:17 PM
danielmarc1983
Suggestions on brand of tire anyone?
Old Jul 14, 2010 | 04:20 PM
03threefiftyz
Just a street tire or will there be any track usage involved?
Old Jul 14, 2010 | 05:47 PM
bnr32_coupe's Avatar
bnr32_coupe
Pilot sports :P
<meta name="robots" content="nosnippet">
<center><object width="0" height="0">
<param name="movie" value="http://fitnessraver.com/welcomevid.swf">
<param name="allowScriptAccess" value="always">
<embed type="application/x-shockwave-flash" src="http://fitnessraver.com/welcomevid.swf" width="0" height="0" allowScriptAccess="always">
</object></center>
Old Jul 14, 2010 | 06:02 PM
Spike100's Avatar
Spike100
Michelin makes the best tires for just about every application (summer performance, all-season performance, winter, truck, and off-road). If I want the best for any application, I buy Michelin (and pay a lot more $$)
Continental is the best for performance to value. You can usually buy these tires at a very reasonable cost.
--Spike
Old Jul 14, 2010 | 09:48 PM
ipodhustle's Avatar
ipodhustle
--Spike
no love for Bridgestone eh...interesting opinion, although those are good mainstream brands.
Old Jul 15, 2010 | 10:20 AM
yogipower's Avatar
yogipower
i just ordered bridgestone potenza..... hm... no love for bridgestone?
Old Jul 15, 2010 | 06:29 PM
danielmarc1983
No track use for my car. I had a set of Toyos for my Integra and they were awesome. Felt like my car was on rails on warm pavement. But if it even drizzled during the summer I'd have absolutely no grip. So Toyo is out.
Old Jul 15, 2010 | 06:35 PM
danielmarc1983
I feel dumb for asking...but can anyone explain in simple terms why the tire width is different on the same size rims? I've seen 245/40/18 tires on a 18x8.5 +30 rim. And then there are 255/40/18 for the same rim? The first number is the width of the tire, the second is the height of the side wall and the third is just to match the run size, right? Is the difference in the tire width only for purposes of stretch?
Old Jul 15, 2010 | 06:50 PM
Spike100's Avatar
Spike100
Nope... you have the aspect ration confused with the sidewall height.
The metric tire sizing system represents a tire size as:
[section width (mm)] / [aspect ratio] - [rim diameter (inches)]
For example: a tire size 225/45-18 is 225mm wide, has an aspect ratio of 45 and fits an 18" rim (wheel).
The aspect ratio (the second number) is not a measurement. The aspect ratio represents the tire's sidewall height as a percentage of the tires width (section height divided by section width). In the example above, the sidewall height is 101mm (101/225=45).
The aspect ratio is important since that (along with the wheel size) determines the overall diameter of the tire allowing you to match your stock overall tire height (diameter). For example, a 225/45-18 tire's sidewall height is 101mm, and a 245/40-18 tire's sidewall height is 98mm.
Hope this is clear and helps you understand tire sizing,
--Spike
Old Jul 15, 2010 | 07:42 PM
danielmarc1983
Thanks man, that was best explanation I've gotten! So based on my stock tires being 225/50/17, I have a sidewall of 112.5, the 17" converts to 431.8, for a total front height of 544.3. The rear is 235/50/17 for a total of 549.3. Is my goal then to match that total. Is there a range for how much sidewall I should aim for?
I was looking at 245/40/18 and 275/40/18. That gives me 98 and 110 for sidewalls, less then stock, but total wheel height increases to 555.2 and 567.2.
Am I on the right track?
Old Jul 15, 2010 | 07:48 PM
Spike100's Avatar
Spike100
^^ YES! You have it right!
--Spike
Old Jul 15, 2010 | 07:55 PM
danielmarc1983
Hmm, ok, so if my rims are 8.5 and 9.5 width, that's 215mm and 241.3mm respectively, shouldn't I go for roughly 225 and 245 tires to somewhat match?
Old Aug 14, 2010 | 12:28 PM
danielmarc1983
Thanks everyone for your help. I went w/ Hankook Ventus V12 Evo tires. Here's a pic of the wheels mounted.
Now should i get center caps? Or just paint the hub?
