Volk TE37 Thread
Old Oct 25, 2011 | 03:35 PM
  #481
sry110's Avatar
sry110
How it looks now:
Test fit / teaser of what's to come:
I think this next time around I will go with a little bit skinnier tires to get the stance a bit more aggressive, thinking maybe 245/35/19 +12 fronts and 275/35/19 +12 rears with a bit more camber to avoid rubbing.
Old Oct 25, 2011 | 06:08 PM
  #482
andz33's Avatar
andz33
Wekfest Name:  303a4524.jpg
Old Oct 25, 2011 | 06:11 PM
  #483
Bmurray350z's Avatar
Bmurray350z
^ should've went a little bit more aggressive... but still looks great!
Old Oct 25, 2011 | 08:46 PM
  #484
vrbigdish's Avatar
vrbigdish
sry110 cant wait to see the new wheels on
Old Oct 26, 2011 | 03:31 AM
  #485
andz33's Avatar
andz33
This was temporary until the new set of wheels come in
Old Oct 26, 2011 | 06:57 AM
  #486
sry110's Avatar
sry110
Originally Posted by gerb
You serious ? lol damn
Yes 10.5 upfront
19x10.5 +12 F 255/35 F 19x10.5 -3 265/30 R
another shot
Untitled by gerb_dc2, on Flickr
Hey gerb you still around? What kind of camber are you running front and rear?
Also any problems with TCS acting weird when you're running 265/30/19 rear tires? That's more than an inch smaller diameter than OEM tire size so I imagine the car doesn't like it too much, but it sure does look good. I'm only asking because I'm deliberating on tire size, spacer thickness, alignment settings, etc.
Old Oct 27, 2011 | 02:32 PM
  #487
blitzkrgct9a's Avatar
blitzkrgct9a
TE37 is simply timeless. My favorite wheel of all time
Old Oct 28, 2011 | 03:20 AM
  #488
gerb's Avatar
gerb
Hey yea I'm still round I just browse from time to time
As for my TCS yes it does act up but by simply turning it off I eliminate that problem. Besides car is more fun when its off.
As for specs
The rear is @ -8 offset and I'm running -4.2 camber but that's going to change soon. I'm planning on switching the 20mm to a 10mm and take some camber out
The front are 10.5 +7 with 255/35 and I'm running -3.5 camber
Keep in mind the picture is hard to tell but I'm riding pretty low
Fenders r rolled n I pulled them like 1-2mm
Nothing extreme (used wet newspaper.method)
Old Oct 28, 2011 | 06:21 AM
  #489
sry110's Avatar
sry110
As for specs
Thanks for the info! I have the less aggressive offsets (+22) so I'm basically trying to figure out what tire size I want, then play around with spacers later. I'm thinking I'll stick with 255/35 up front, or possibly 245/35. The rears are the question. I could go the safe route and use 275/35 with a 10mm spacer and OEM camber (rear fenders are rolled), or go skinnier tires and more spacer, more camber....but I'm not as low as you were in that picture so I'm not sure that setup would look right for me. If only tires were a lot cheaper to change out, and if only the fear of the tire shop damaging my wheels at every change-out wasn't lingering.
Old Oct 28, 2011 | 04:34 PM
  #490
dtsj350z's Avatar
dtsj350z
Just pick these up. I'll have more pics once i get the tires mounted.
Old Oct 28, 2011 | 04:48 PM
  #491
JPsZ's Avatar
JPsZ
^^ nice wheels! I miss them already
Old Oct 29, 2011 | 09:26 PM
  #492
dtsj350z's Avatar
dtsj350z
^^Haha. Yeh JP, i'm hunting for a set of black lugs to match the black stickers.
Old Nov 28, 2011 | 10:20 AM
  #493
sry110's Avatar
sry110
I didn't have any luck searching so instead of starting a new thread I though I'd try my luck here: Anyone have pictures of a 265/35/19 tire on a 19x10.5 wheel? Curious how stretched it looks. I have a set of LE37t's with the standard 19x10.5 +22 rear size, but I'm looking to maybe put a 15mm spacer for +7 net offset and thinking I might need to go 265/35/19 instead of the "safe" route 275/35/19 to make it fit without excessive negative camber.
Old Nov 28, 2011 | 11:54 AM
  #494
VQpoweredZ's Avatar
VQpoweredZ
I could be wrong but I think I remember reading once that Toby was running a 265 on his old SF Challenges a while ago. On the rear 10.5'' wheel that is.
Old Nov 28, 2011 | 12:00 PM
  #495
sry110's Avatar
sry110
Ah cool thanks for the heads-up. I'll search his old stuff and see what I find.
Old Nov 28, 2011 | 12:02 PM
  #496
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I had a 265 on my 18x10.5 and I have a 265 on my 19x10. What are trying figure out? The stretch?
Old Nov 28, 2011 | 12:24 PM
  #497
VQpoweredZ's Avatar
VQpoweredZ
So I'm super bored and managed to find this for you. This is what I was referring to. As for his offsets with the Challenges I don't know, but you could shoot him a PM I'm sure he'll help you out. Old thread is old... 2009!
Post #2 and #7.
https://my350z.com/forum/media-share...g-z-shoot.html
Old Nov 28, 2011 | 12:25 PM
  #498
sry110's Avatar
sry110
Yes, exactly. I'm trying to find that breaking point of pushing my wheels out as far as possible without the tires looking too retardedly stretched. i.e. I don't want this:
but I want a little bit of stretch so I can get the wheels poked and cambered out a bit more for a more "flush" look. The other factor is that my ride height is not "slammed", instead the front tires are just barely tucked under the wheel arches and the rears have maybe a little less than 1/2" clearance from tire to wheel arch. So a super stretched tire won't look right with that much sidewall exposed.
Old Nov 28, 2011 | 12:32 PM
  #499
sry110's Avatar
sry110
Post #2 and #7.
Nice recon work Dan! I owe you a beer and like 20 of my finest internetz.
Old Nov 28, 2011 | 12:33 PM
  #500
AdvanZ33's Avatar
AdvanZ33
That's why I went from a 275 to a 265 on my 18x10.5. 265 is perfect IMO. Very mild stretch.
