Volk TE37 Thread
Old Feb 21, 2013 | 12:28 PM
  #921
gs400speed23's Avatar
gs400speed23
Fzero coming back!
Old Feb 21, 2013 | 01:55 PM
  #922
Murfdizzle21's Avatar
Murfdizzle21
Hey there...
Old Feb 21, 2013 | 03:04 PM
  #923
gs400speed23
^ not too shabby
Old Feb 23, 2013 | 07:38 PM
  #924
mdd's Avatar
mdd
fzeros are interesting didnt think they had that much color variation
Old Feb 24, 2013 | 01:25 AM
  #925
gs400speed23
You'd be shocked if you look closely into the details. It changes shade in different lighting. No wonder its un replicable.
Old Feb 24, 2013 | 02:38 PM
  #926
mdd's Avatar
mdd
+12 or +22?
Old Feb 24, 2013 | 05:31 PM
  #927
gs400speed23
+12 ofcourse
Old Feb 24, 2013 | 05:46 PM
  #928
sry110's Avatar
sry110
Old Feb 24, 2013 | 06:57 PM
  #929
Bmurray350z's Avatar
Bmurray350z
feels like its been a year since ive seen a pic of your z! keep em coming!
Old Feb 24, 2013 | 07:56 PM
  #930
sry110's Avatar
sry110
Mine's been tucked in the garage since December and I've been spending all my time playing around with the S4. Itching to get the Z out again though!
Old Feb 24, 2013 | 08:03 PM
  #931
Bmurray350z
do eeeetttttttttttttt
Old Feb 24, 2013 | 08:45 PM
  #932
angelo350z's Avatar
angelo350z
+1000
One of my favorite Zs on the site
Old Feb 25, 2013 | 07:23 AM
  #933
sry110's Avatar
sry110
aw joo gais
Old Feb 25, 2013 | 06:29 PM
  #934
sry110's Avatar
sry110
Here are a few old ones right after I first put on my LE37t's, pre-decals:
Old Feb 25, 2013 | 09:15 PM
  #935
gs400speed23
Time for an sbc wing!
Old Feb 25, 2013 | 11:59 PM
  #936
Chadro's Avatar
Chadro
These would look sweet on a Silverstone.
Old Feb 26, 2013 | 12:12 AM
  #937
angelo350z's Avatar
angelo350z
Looking good as always sry110. I know we had this conversation before, but please freshen my memory. You ran 5 mm front and 10 mm rear spacers with your LEs, correct?
Old Feb 26, 2013 | 03:29 AM
  #938
sry110's Avatar
sry110
Thanks dude! The specs are 19x9.5 +22 front with 10mm spacer (making +12 net offset), and 19x10.5 +22 rear with 15mm spacer (making +7 net offset). Tires are 245/35 and 275/35 front and rear.
Old Feb 26, 2013 | 03:52 AM
  #939
angelo350z's Avatar
angelo350z
That's right, I'll try those with sizes. Are you running extended studs? I'm running 255/35 and 285/35, but my tires seem to have more of a strech than yours so they might work. Keep the pics coming . I'll get my Z hopefully by July .
Old Feb 26, 2013 | 06:49 AM
  #940
sry110's Avatar
sry110
Yes I am running extended studs front and rear, I believe 10mm longer than stock (can't quite remember). But since I eventually wanted 15mm spacers in the rear, I ended up using 15mm spacers w/ built-in studs, which are secured to my rear hubs via the extended studs. I'm lucky my wheels have the cut-outs in the back to accommodate the longer studs!
When I was running 255/35 and 285/35 I was also on +22 offset wheels, but with 5mm front and 10mm rear spacers. I had no rubbing issues, but my ride height was also higher. Never tried 10mm and 15mm spacers on that setup but I think I would have had some rubbing. It's worth trying, though....worst case you end up with one extra set of spacers.
Where is your Z? I notice in your info that you are now in Guam. Did they put your Z on the slow boat to get over to you?
