Will this offset work?
Old Nov 12, 2003 | 04:36 AM
JJGALIA's Avatar
JJGALIA
Question Will this offset work?
I'm thinking of going with Axis Milanos 8.5 and 9.5 rims with 245 front 275 rear and 19 all around. I have a choice of 15 or 35 offset in the front and 20 or 40 offset in the rear. I want them to look good. Would the 15/20 front and rear stick out too much? Has anyone done this yet? Thanks!
Old Nov 12, 2003 | 05:01 AM
ether's Avatar
ether
i think you might be pushing it with the +15 in the fronts... the most I've seen with out problems is +17s both fronts and rears with the 8.5s and 9.5s
here is my ride for refrence. these are just a bit more conservative than the +17s.. http://www.cardomain.com/id/jdm_z33 they are flush with the body with no rubbing issues with Nismo suspension and 245/35s and 275/35s
hope that helps
Old Nov 13, 2003 | 06:29 AM
JJGALIA's Avatar
JJGALIA
Ether, Thanks for the help. I love the offset on you rears especially. Great look. I'm just hoping I can get my Milanos to fit that way.
Old Nov 13, 2003 | 04:36 PM
N74DV's Avatar
N74DV
15 will work... I have 8.5's in the front with a 12mm offset.... the wheel is just barely inside the fender. I have an Eibach drop too
I have had no problems as all with this...
Old Nov 13, 2003 | 06:47 PM
JJGALIA's Avatar
JJGALIA
N74DV, What's your offset in the rear? Thanks for the info. That's a big help!
Old Nov 13, 2003 | 06:58 PM
N74DV's Avatar
N74DV
I have 19x9.5's in the rear with a 27 offset. I am running 285/35/19's and have no problems with rubbing
hulkout
Tuning
Sep 30, 2015 12:33 PM
