Does Axis S5:F wheels come in 18" x 9.5" ???
Old Aug 18, 2010 | 01:19 AM
huanandonly's Avatar
huanandonly
Smile Does Axis S5:F wheels come in 18" x 9.5" ???
I have a 2007 base Z, running 18" stock wheels right now and I want to upgrade but I also want to keep close to these stock parameters...so the configuration I'm interested in is:
FRONT 18" x 8.5", Offset +15 to +25, Tires 245/40/18
REAR 18" x 9.5", Offset +15 to +25, Tires 275/40/18
I am looking at the Axis S5:F wheels (see pic)... BUT they don't seem to make 18 x 9.5 for the REARs ... only 18 x 8.5's. Is this correct?... Am I missing something here??...Any other 18" configuration possible?...If this is not an option, then... would bumping up to 19" be that much of a difference in terms of handling?... would they feel much more "heavier" in steering than the 18"?
I'm a newbie here... so any help/suggestions would be great...thanks!
Attached Thumbnails Does Axis S5:F wheels come in 18" x 9.5" ???-s5fsil.jpg
Old Aug 18, 2010 | 05:45 AM
Not exactly. Wheels are wheels. You can put them on the front or rear. There is no dedicated front wheel or dedicated rear wheel.
Old Aug 18, 2010 | 10:10 AM
huanandonly
yes, but if i need to keep to the suggested configuration, don't I need 18 x 9.5 for the rears?.... NOT 18 x 8.5 ??
Old Aug 18, 2010 | 10:37 AM
str8dum1's Avatar
str8dum1
no, the 275 will fit fine a 8.5" rim
Old Aug 18, 2010 | 11:01 AM
huanandonly
ooooh..ok, thanks.
and back to the second part of my question:... would bumpin up to 19's be THAT much different, in terms of handling compared to the 18's wheels? (btw...im not doing any track use)
Old Aug 18, 2010 | 11:51 AM
No. There is no need to stagger wheels. You can run the same size all around.
Old Aug 18, 2010 | 11:53 AM
ooooh..ok, thanks.
No. Wheel diameter is insignificant. Tires matter.
Obadabot
Jun 18, 2023 11:31 PM
