wheel installed and ailgnment done but.....
on
whenever i'm on on-ramps or faster turns and i throttle, the slip light turns on. i did an alignment right after the wheels are on and everything seems like they are in spec except for the negative camber in the front. could it be the tires or the alignment specs??? TIA
wheel specs
19x9.5 +12 Hankook evo v12 245/35
19x10.5 +12 Hankook evo v12 275/30
alignment specs
(L)front (R)front
camber: -2.0 -2.4
Caster: 8.8 8.9
Toe: .04 .05
(L)rear (R)rear
Camber: -1.8 -1.9
Toe: .07 .09
wheel specs
alignment specs
(L)front (R)front
camber: -2.0 -2.4
Caster: 8.8 8.9
Toe: .04 .05
(L)rear (R)rear
Camber: -1.8 -1.9
Toe: .07 .09
Wrong size tires, you should have installed 275/35-19
on
This is your friend while shopping for wheels/tires.... http://www.miata.net/garage/tirecalc.html
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
