Need a quick answer
Need a quick answer
Whats up guys? Here's my situation. I'm about o purchase Works Cr-Kai, and i recenty purchased new tires a couple weeks ago, and now want to get new wheels. I need to know if my tires will fit a 18x8.5 +25 offset front, 18x9.5 + 20 offset rear.
I think the size on my tires is, front 225/45/18 rear 245/45/18.
I think those are the right sizes on everything. Z1 performance said that the +20 in the front was discontinued, but the +25 would be almost the same thing. Anyway, will those size wheels fit those tires? Thanks a lot.
on
Yes they will fit. They are not wide enough for my taste, but yes they will work.
For that setup the perfect option imo for you would be 245/40 and 275/40, but if you already have tires then you can use them.
got it. Thanks guys. I really appreciate it. A dealer is gonna give me a price check on a wheel/tire package today on the correct tires. In the mean time, does anyone know somebody that wants some new tires?
Okay, well dang. A guy on here is selling his used and tires. I think thats my best bet. The sizes on the wheels are 18x8.5 +25 and 18X9.5 +20. and the tire sizes are 245/40/18 and 275/35/18. He also told me he had a 10mm spacer. How do you guys think this will look?
on
I have +20, 18x9.5 CR with 275/40/18
and I just installed 10mm spacer (so now is +10 offset), it rub but very little
And the front is +25, 18x8.5 with 245/40/18 (+20 one was discontinued)
Installed 20mm spacer (+5 offset now), no rubbing issue...
I am lowered, and std camber. hope this is help
will look lame, not tall enough of a rear tire. But 275/35-18 makes a reat front tire on a 9.5. You need 275/40 rears.
