wheel fitment suggestions?
Old Sep 23, 2010 | 04:07 PM
driftZ33's Avatar
driftZ33
Default wheel fitment suggestions?
i am looking at getting a set of ADVAN RZs in 18x9 with a +25 offset for the front and 19x10 with a +25 offset for the rear in gunmetal for my nismo. with a set of 245/40/18s on the fronts and 265/35/19s on the rear will i have any issues rubbing?
Old Sep 23, 2010 | 04:36 PM
omsin523's Avatar
omsin523
Ive been told, and seen some setups like yours with a 265/35/18 up front and for rears 275/40 or 285 just depends on your suspension setup. But you should be fine just depending if your lowered, and how much.
Old Sep 23, 2010 | 05:39 PM
This is the similar to:
Track 18/19" v.2
18/19-inch Track and GT wheels V2
The redesigned Rays forged Track model rims were an instant hit. The 2006 and 2007 350Zs featured these wheels on the Track and Grand Touring trim packages. The increased size and thicker design of the version 2 wheels has led to a significant increase in weight per wheel.
Cost
Expect to pay around $1500 or more for a used set in good condition.
2006
Super-light Forged Aluminum Alloy
Front
Offset: +30mm
Weight: 21 lbs 4 oz
Tire: Bridgestone RE050A 245/40/18
Rear
Offset: +30mm
Weight: 29 lbs 8 oz
Tire: Bridgestone RE050A 265/35/19
Good choice.
Old Sep 23, 2010 | 06:12 PM
terrasmak's Avatar
Not even close, conservative tires and offsets. It would be the same as adding a 5mm spacer to your stock wheels.
Old Sep 23, 2010 | 07:23 PM
driftZ33's Avatar
driftZ33
the track V.2 wheels are the same as the stock nismo wheels and i like how they fill the wheel well i just don't care for the look of them. i like multi-spoke wheels like the advan, ssr, and bbs setups. i've also even thought about going 19" in the front my biggest issue there is that i use the car for drifting occasionally so clearance is always key. the +30 offset on the nismo wheels is just about perfect, unfortunately i am having a hell of a time finding wheels i like in the sizes i want with that offset.
