19" Tire size question
Old Sep 23, 2010 | 10:45 PM
nowheremangta's Avatar
nowheremangta
Default 19" Tire size question
For 19x9 +22 front, 19x10 +25 rear
Some has setup
a) 225/40/19 front, 245/40/19 rear
b) 235/35/19 front, 265/35/19 rear
c) 245/35/19 front, 275/35/19 rear
How is the difference between them, and I don't know how to choose?
and how should I interpret the aspect ratio (height to width)?
p.s. I want some setup that fit the VDC system.
Old Sep 24, 2010 | 03:11 AM
DavesZ#3's Avatar
DavesZ#3
C is the "standard". Read the post on the 3rd page of the Top 100 Questions thread about "slip light" and tire sizes.
Old Sep 24, 2010 | 03:18 AM
I am not going to check and compare these for you. But I suggest you do so: http://www.dakota-truck.net/TIRECALC/tirecalc.html
Old Sep 24, 2010 | 07:40 PM
nowheremangta
Thanks.
I finally learnt about the VDC system.
But I found that setup a and setup c will probably fit the car.
If I run 19" with setup a (thin tires), will it be not so stable?
Old Sep 24, 2010 | 08:20 PM
Originally Posted by nowheremangta
Thanks.
I finally learnt about the CDC system.
Members often run a "stretch" tire: width too short for wheel.
or a "fat" tire: tire width too wide for wheel.
But there is very little interest in standard sizing (recommended by tire manufacture). I guess stretch and fat are cool.
Old Sep 24, 2010 | 11:08 PM
nowheremangta
If we match the circumference of tires to fit the VDC,
The tire width and height should be difference from the 18" OEM ones.
What tire sizes are recommended by tire manufacture?
Old Sep 25, 2010 | 03:52 AM
Look at the Track 18/19" v.2 wheel. Nissan puts a 265 mm tire on a 10.0 inch wheel. This is conservative.
Reference: http://www.*********.com/zwiki/350Z_...Specifications
Old Sep 25, 2010 | 01:04 PM
hwcustoms's Avatar
hwcustoms
Go with c
/thread
footballmania32
Wheels Tires
Oct 20, 2015 09:08 PM
Paul.
Oct 16, 2015 07:34 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
