wheel locks
Old Sep 24, 2010 | 06:13 AM
mimobeatz's Avatar
mimobeatz
Default wheel locks
As u all probably know. The 05 enthusiast z coupe has wheel locls. But the stupid *** dealer lost the key for the locks. So i wanna know if i theres like a universal wheel lock or sumtin u could get? Thanks
Old Sep 24, 2010 | 07:32 AM
DavesZ#3's Avatar
DavesZ#3
Moved to proper forum
OEM wheel locks? They should have come with a registration card that had a code on them so you can order a replacment from McGard.
Most any wheels locks come with some kind of process that allows you to get a new key.
You can always get a wheel/tire shop to remove them for you but that typically ruins the locks - i.e. remove them and throw away and get new ones.
If you're brave, you can attempt to remove them yourself like a thief normally does. Hammer on a 3/4" socket over the lock nut then use an impact wrench to remove them.
Old Sep 24, 2010 | 08:55 AM
Dblock55's Avatar
Dblock55
You could use the 3/4" socket method, i actually just did that myself with a different set of lugs... only thing is dont use an impact gun... it will make the socket slip, use a breaker bar or torque wrench and slowly try to ease it off, dont apply to much torque or itll split and ruin the lock and the socket and then youll be really screwed lol
Old Sep 24, 2010 | 09:07 AM
mimobeatz's Avatar
mimobeatz
So if i get them removed i can just buy new ones? And yeah they are oem locks. They have some for sell on amazon too
Old Sep 24, 2010 | 10:34 AM
DavesZ#3's Avatar
DavesZ#3
Yes, have them removed and get new ones if they make sure feel safer.
Old Sep 24, 2010 | 10:47 AM
terrasmak's Avatar
Go back to your dealer, there are only 8 different keys. Most Nissan Mechanics will have the full set, and can remove them for you.
Obadabot
Jun 18, 2023 11:31 PM
