To those who are cambered and lowered.....
Old Oct 7, 2010 | 10:35 AM
DieselOne's Avatar
DieselOne
Default To those who are cambered and lowered.....
To the guys that are running some negative camber and lowered, are you getting horrible tire noise?
I'm dropped on DF210's running about -2.5 camber front and rear with 245/35 275/35 tires. I am getting horrible tire noise. Just a constant drone that sounds like a off road truck. Ive ran Nitto Neogens and Nankang Ultra Sports both with truck like noise.
Any of you guys getting a quiet ride? If so, what's the secret? Some guys tell me it's cuz I'm cambered on 35 series tires but some other guys say camber and sidewall dont have anything to do with it.
Old Oct 7, 2010 | 10:49 AM
ispanico350z's Avatar
ispanico350z
: Confuso:: Confuso:: Confuso:: Confuso:
Old Oct 7, 2010 | 10:50 AM
marques1's Avatar
marques1
In my experience, It has alot to do with tire selection! I was rolling on kdw's which are very popular on this forum and couldn't stand the noise. So, I ended up selling them and actually bought cheaper tires that where quieter. Actually the nitto's are usually quieter than other tires. Also, -2.5 degrees of camber is quite a bit. Also, make sure that your toe is in-line. If it is not your tires will be fighting each other and making a loud humming noise.
Old Oct 7, 2010 | 10:52 AM
bmccann101's Avatar
bmccann101
the tires themselves have alot to do with it.. but the noise issue comes from toe.. and feathering.. and cuases the brunt of tire wear on our car, espec when lowered. Im down on stance lx, camber bar in rear, and nothng did more for my tire wear n noise like my toe delete bolts in the rear and a high end alignment.
im at zero toe in rear and -1.5 camber.. now i get to keep my tires around like a normla person.
I suspect this is your numebr ONE issue, tire choice is surely number two.
Old Oct 7, 2010 | 11:37 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
better tires that can deal with camber, and running less camber in the first place
-2.5, on those tires, on a street car, when all you're running is a set of springs is an excercise in futility. Replace your tires, set the camber back to the nominal range of the factory service manual, and all will be right with the world once again
Old Oct 7, 2010 | 11:48 AM
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by DieselOne
what's the secret?
Amen!!
the answer is obvious OP, you know it...why ask it...
/thread...
-J
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
