What size tire will give the beSt handling with 10.5x18
Old Oct 31, 2010 | 10:22 PM
crsracing19's Avatar
crsracing19
Default What size tire will give the beSt handling with 10.5x18
Ok so I'm runnig 10.5x18 in the rear and I'm Looking to switch over to toyo proxes r888. For future track days. My current tire is nitto nt05 with 295/35/18
But the proxes r888 don't come in that size the closest iv seen are
295/30/18 which in my mind he runniing to low of a profile for the track
or 305/35/18 which idk if that would fit the 10.5 rears and if it did would it work well for the track
Old Nov 1, 2010 | 08:05 AM
crsracing19
Ok I'll phrase it a different way what would work better as a track tire size for a 10.5 rear tire. 295/30/18 or 305/35/18
will the 305/35/18 fit?
Old Nov 1, 2010 | 08:18 AM
terrasmak's Avatar
Is your car NA or FI, and how much power does it make?
Old Nov 1, 2010 | 08:27 AM
crsracing19
Currently na I'm I'm saving my engine for last
Old Nov 1, 2010 | 08:39 AM
terrasmak's Avatar
275/40-18 will be great, and yes they offer them. 275/35 front also.
285/30 front and 295/30 rear would also work great,
Old Nov 1, 2010 | 08:54 AM
crsracing19
Any idea if the 305/35/18 will fit?
I'm just not a fan of running that low a profile 30's would look a little low
Old Nov 1, 2010 | 09:46 AM
terrasmak's Avatar
Yes it will fit, but these are RACE tires, who freaking cares about the looks (unless you just go to the track to pose)
Old Nov 1, 2010 | 09:56 AM
ITOzann's Avatar
ITOzann
275/35 but I always liked 265/35
Old Nov 1, 2010 | 12:43 PM
terrasmak's Avatar
Also do you have the proper springs to run these, if you don't have a 14kg spring up front i wouldnt bother and just stick to NT05's
Old Nov 1, 2010 | 03:23 PM
crsracing19
Why do you need those particular springs to run those tires?
Old Nov 1, 2010 | 04:54 PM
TAHorizon's Avatar
TAHorizon
Yes, that is the tire size I would recommend, but you'll more than likely need rolled or cut fenders.
Old Nov 1, 2010 | 05:57 PM
terrasmak's Avatar
You really don't need them unless you want the can to handle properly.
You should be able to do the 305's in the rear just fine on your NT03's, just remove any spacer you have and you may need a slight roll.
You coming out and running the HPDE at Cal Speedway in two weeks?
Old Nov 1, 2010 | 08:45 PM
crsracing19
No I'm just trying to prep for a couple consecutive track days in January with my buddy before he move to another state
Old Nov 2, 2010 | 08:22 AM
scotts300's Avatar
scotts300
285/30/18 x 4. You don't have the offset for anything much larger. 305/35 is WAY too tall and requires a much higher offset.
Old Nov 2, 2010 | 01:16 PM
ZS14RR's Avatar
ZS14RR
225/35/18........
Old Nov 2, 2010 | 01:20 PM
Nexx's Avatar
Nexx
175/15/18 according to the hellaflush guys.
Old Nov 2, 2010 | 01:37 PM
scotts300's Avatar
scotts300
Originally Posted by ZS14
225/35/18........
Old Nov 2, 2010 | 01:45 PM
03threefiftyz's Avatar
03threefiftyz
Don't be ridiculous.....a 195/25/18 is what he is looking for per the "hellaflush hand book".
Old Nov 2, 2010 | 06:17 PM
terrasmak's Avatar
with -75 offset.
OP your rocking the NT03's right, 10.5 +30 ? If so , 305 will be just fine.
Old Nov 2, 2010 | 07:07 PM
ITOzann's Avatar
ITOzann
