How flush?
Old Nov 21, 2010 | 01:06 PM
Jwill's Avatar
Jwill
Thanks guys. I'll let you know how it looks and post some pics. I need to get tires to fit but no money. Found a guy on here, gruppe-s or something like that. Has some good deals lol. Are those sizes, 245/40 f and 275/40 r good for that size wheels?
Old Nov 21, 2010 | 01:49 PM
jaaf's Avatar
jaaf
Originally Posted by Jwill
Yo jaaf, what size tires are you running?
im running 225/40 all around
Old Nov 21, 2010 | 01:51 PM
jaaf's Avatar
jaaf
well what look r u going for? slammed n hellaflush or low with some meaty tires? i would do 245/35, 265/35 if ur jus gonna lower on springs
Old Nov 21, 2010 | 02:11 PM
Jwill's Avatar
Jwill
Well I'm lowering about 1.2 inches, and I kinda just want it to be dropped and flush.
Old Nov 21, 2010 | 02:54 PM
terrasmak's Avatar
Then you really don't want 35 series tires, they add fender gap do to the fact they are too short for the car.
Old Nov 25, 2010 | 05:57 AM
rich2342's Avatar
rich2342
Same tire height as stock, its proper. No VDC/TCS/ABS problems. Not everyone want to screw their car up with the lowrider (ittybittypokyouty) look. Some people do care about performace, handling, ride quality and looks. Hella flush has nothing to do with any of that.
What's the proper size 18x9.5 18x10.5 rims that won't interfere? I see people running all kind of crazy sizes, but no mention of Vdc issues?
Old Nov 25, 2010 | 07:06 AM
NA&CH's Avatar
NA&CH
on my old set up i ran 265-35 and 285-35 combo. no problems at all.
I am looking for a tire setup for my new rims. 18x9.5 +20(looking for 20-25mm spacer for the rear). I thinking 265 all four.
OP the 40 series will be good if you don't go any lower. I love the Kai's +12 all four
Chris
Old Nov 25, 2010 | 07:54 AM
rich2342's Avatar
rich2342
I was thinking of going with 40 series. Id rather the 35, but i won't be doing an extreme suspension I don't think.
Old Nov 25, 2010 | 10:20 AM
terrasmak's Avatar
Depends on offset, my street setup is 18x9.5 +15 front with 255/40-18 (had 245/40-18 for the past year) and 18x10.5 +10 with 275/40-18 , and my current track setup is 18x9.5 +15 275/35 front and 18x10.5 with 275/40. I can also run 285/35 rears or (if my class allowed) 295/35 rears.
I am a huge fan of non staggered or changing to only a 10mm stagger, but i feel the car handles so much better when you keep the stagger in tire height from front to back. I would never recomend running 275 or 265/35 all around
Old Nov 25, 2010 | 04:29 PM
rich2342's Avatar
rich2342
With the above sizing and +15 offsets what tires should I run? 245/40/18 front and 275/40/18 rear? Will that avoid vdc issues?
Old Nov 25, 2010 | 05:47 PM
terrasmak's Avatar
No problems with VDC and you could run a 255/40 up front if you want.
Old Dec 3, 2010 | 08:58 AM
Z_flip's Avatar
Z_flip
here you go... you'll need this.
http://www.more-japan.com/fic-wheel-...s-10mm-spacer/
Old Dec 4, 2010 | 12:55 PM
Jwill's Avatar
Jwill
Is a 245 up front gonna be stretched a lot with a 9.5 +12?
Old Dec 4, 2010 | 12:58 PM
terrasmak's Avatar
Just a hair, nothing like the stupid stretch and lowrider poke guys.
Old Dec 4, 2010 | 01:01 PM
Jwill's Avatar
Jwill
So would a 245 be the tight size or go with a 255/285 or something
Old Dec 4, 2010 | 06:22 PM
terrasmak's Avatar
I wouldnt do a 285 on a 9.5, but you do know you can easily run a 255 front with a 275 rear. You car will actually handle better too.
Old Dec 4, 2010 | 06:29 PM
Jwill's Avatar
Jwill
Really? Would you recommend that?
Old Dec 4, 2010 | 06:53 PM
  #38
9.5 inches is 241.2mm.
Tire tread is 245mm.
This will work.
Old Dec 4, 2010 | 07:23 PM
  #39
Jwill's Avatar
Jwill
Alright bro. Thanks
Old Dec 4, 2010 | 07:24 PM
  #40
terrasmak's Avatar
I've run both, and right now i have 255/40-18 front and 275/40-18 rear. Front is sitting at +15 , 1 inch drop and -1.7 camber with a slight pull.
