New rims and tires.
Old Nov 27, 2010 | 03:49 AM
gixxer1000's Avatar
gixxer1000
Default New rims and tires.
Hey guys I just installed a new set of 20" axis penta on my 2005 350z.. The rims arrived mounted and balanced. We installed them and now I get a vibration at speed between 50-80mph And I get a pull to the right now?? The car is not lowered and the stock 17 never had a vibration issue or anything ?? When you put 20s on the 350z do you have get everything adjusted after .. Keep In touch
Old Nov 27, 2010 | 04:36 AM
KornerCarver's Avatar
KornerCarver
It sounds like your new wheels and tires may not be correctly balanced. I would take it to a shop and have the balance checked. You should not need to adjust anything when going to 20" wheels.
Old Nov 27, 2010 | 05:20 AM
kham25's Avatar
kham25
Perhaps a balance issues or maybe you bent a wheel already!! Ive bent new 19 inch wheels in a matter off days driving here in the city. I went through your senerio before..
Old Nov 27, 2010 | 05:32 AM
gixxer1000's Avatar
gixxer1000
Yea that's what I was thinking.. I don't think they are bent lol .. Do you think I should get my aliment checked?
Old Nov 27, 2010 | 05:36 AM
kham25's Avatar
kham25
Alignment dont cause vibration from what i know.. Rebalance both front wheels and go from there.. If that checks out then check tires.. Ive recieved Out OF Round tires from tirerack once and vibrated like a ****.. Let me tell you man having aftermarket rims can give you a focking headache
Old Nov 27, 2010 | 05:49 AM
cheshirecat79's Avatar
cheshirecat79
Hubcentric rings. Do those wheels require them? Did you install them if so?
Old Nov 27, 2010 | 05:55 AM
gixxer1000's Avatar
gixxer1000
Thanks ... You think I sould only rebalance the front? What about an aliment for the pulling to the right?
Old Nov 27, 2010 | 05:59 AM
gixxer1000's Avatar
gixxer1000
Yes they have the hub rings in.
Old Nov 27, 2010 | 06:03 AM
DavesZ#3's Avatar
DavesZ#3
That would be my first guess - a lot of aftermarket wheels require them because of generic sizing.
Pulling to the right - could be alignment, you should be getting that checked annualy anyway. If aligned, a defective tire could cause "radial pull".
Old Nov 27, 2010 | 06:22 AM
Waiz's Avatar
Waiz
In for fotos
Old Nov 27, 2010 | 06:51 AM
gixxer1000's Avatar
gixxer1000
Will do..
Old Nov 27, 2010 | 04:32 PM
ReelBigAndy's Avatar
ReelBigAndy
Couldn't hurt to check the tire pressure, that could account for the pulling
Old Nov 27, 2010 | 08:52 PM
Waiz's Avatar
Waiz
Pressure check is a good suggestion, I have a feeling it's balancing and alignment related.
Take it to a reputable shop and get an inspection.
Old Nov 27, 2010 | 08:58 PM
350z_Boi's Avatar
350z_Boi
It's either your tires or check your lug nuts. It might be loose..
Old Nov 28, 2010 | 06:42 AM
gixxer1000's Avatar
gixxer1000
Default No luck..
Hey guys I took the wheels yesterday to discount trie and the figured out the issue with my penta.. The rebalanced then and re installed the right front. So I get the car back after it was do and I noticed the damage my front rim!! Guess they rushed one of the lug nuts And damaged the nut hole around it. They offered to either get me a new rim or have some rim place repaint the damage?? I do know what to do ? I was so pissed not even 20 miles ..
Old Nov 28, 2010 | 07:11 AM
These are 20-inch wheels? Surprised that Discount Tire would even touch them.
Old Nov 28, 2010 | 07:12 AM
terrasmak's Avatar
Thats why i always tell them "NO AIR TOOLS" and i also have aluminum lugs. Tire monkeys running loose with air impacts are not good for aftermarket wheels.
Old Nov 28, 2010 | 07:13 AM
tylerxfire's Avatar
tylerxfire
me no what tell u
Old Nov 28, 2010 | 07:17 AM
Photos?
Old Nov 28, 2010 | 07:23 AM
gixxer1000's Avatar
gixxer1000
I tried to take a pick yesterday but it was to dark. Should I try to get a new rim? Or let the rim place paint it? Or just leave it ?
