Appropriate tires for 17"X8.5" and 17"X9.5"?
I was wondering what the largest tires are that will fit on 17"X8.5" wheels in the front and 17"X9.5" wheels in the rear with stock suspension without rubbing the outer wheel wells. I was thinking 245/45 in front and 275/40 in rear. Also, what offset would be appropriate for those size wheels to insure no rubbing w/ stock suspension?
I run 275/40-17 front and rear on 17x9 wheels with 35mm offset... stock springs/shocks... no rubbing fenders or suspension... Wheels are Enkei RPO2J.
I don't think you can fit a 275 onto an 8.5" wide wheel, so go with 255/40-17 and you should be fine.
Hope that helps.
PeteH
Hope that helps.
PeteH
I would agree with ares, except I don't think you can find a 275/45/17 tire. I think the biggest 45/17 aspect ratio tire you will be able to find is a 255/45. So that would be my recommendation for the rear. Fronts, 245/45s.
Lou
Lou
Hope that helps.
PeteH
Hope that helps.
PeteH
Thanks to all for the feedback. Any more info on appropriate offsets?
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
