Brakes pulling caused by wide tires on rutted road?
Old Feb 21, 2011 | 09:25 PM
winchman's Avatar
winchman
Default Brakes pulling caused by wide tires on rutted road?
Every so often the steering wheel will pull to the right or left when I'm braking gently. It usually happens when I'm approaching a traffic light at an intersection on a busy highway. The brakes and steering are otherwise fine. The tires are good and properly inflated.
I suspect it's the combination of the wide tires and ruts in the pavement caused by lots of heavy truck traffic. The tire will ride on the edge of the rut, causing an unbalanced force on the steering system.
Has anyone else noticed this and reached the same conclusion?
And yes, I searched, but found no relevant threads.
Old Feb 21, 2011 | 09:29 PM
terrasmak's Avatar
Crowned roads suck in all cars.
Old Feb 21, 2011 | 10:36 PM
Chaser720's Avatar
Chaser720
Lemoned Z
Agreed. Nothing to worry about.
Old Feb 22, 2011 | 12:16 AM
Jennifer 2's Avatar
Jennifer 2
Winchman, most everybody in the sports car world refers to this condition as Tramlining. Your fathers Oldsmobile and all the other giant old domestic cars favored by grumpy old men didn’t exhibit this phenomenon. Sporty cars have more aggressive steering geometry. Also less caster, a lesser amount of steering trail (for sharper steering response), and healthy amount of negative camber. Add to this, wider gripper tires with stiffer lower profile sidewalls and you have a car that at low speeds will find every ridge and rut in the road.
This condition can really sneak up on you as your high performance tires wear down. As the tread wears down the little notches and grooves separating the tread blocks disappear effectively putting more rubber on the road. This condition added to the fact that the lower tread height allows less flexibility in the tread blocks will make the tires want to grab the ruts and pull into them even more. When I last changed from my thoroughly worn out performance summer tires, to the same size of less aggressive All-Seasons for the winter, all vestiges of tramlining disappeared.
Old Feb 22, 2011 | 01:27 AM
midz350's Avatar
midz350
STFU and go back to kitchen
J/K actually it was very informative. Thanks
Old Feb 22, 2011 | 03:48 AM
No brake-front suspension is perfectly balanced. It will pull one way on the other depending on factors such as tires and alignment. Only you can figure out if the pull is extreme.
Old Feb 22, 2011 | 03:56 AM
SoldzMyZ's Avatar
SoldzMyZ
ahhh ive notice this before on the freeway slowing down! eeekkkkkk
Old Feb 22, 2011 | 05:36 AM
bmccann101's Avatar
bmccann101
Default bahahhahahahaha!
Hilarious, Jenn you are a brave woman. this forum is choc full of yuppie Alpha male idiots, of which I am a proud card holding jack@ss member since 03.
Every seven years the planets align, the earth opens up, and i get a chance to whip this picture back out, and for that I thank you truly.
Im also totaly playing. No ill intent whatsoever, i can dish it, and i can take it too.
Old Feb 22, 2011 | 06:42 AM
scotts300's Avatar
scotts300
I've learned more from her than I have from 95% of the other members on here.
Old Feb 22, 2011 | 07:17 AM
Arvin89's Avatar
Arvin89
Agreed.
And I thankfully don't get this in my Z, but my dads 530 with the M sport suspension is NOTORIOUS for this. It finds any rut in every road. Lol. I'm guessing its the combo of sport suspension and his low profile/wide tires like stated. Its not much to worry about, but it can be annoying.
Old Feb 22, 2011 | 07:19 AM
bmccann101's Avatar
bmccann101
listen, Im at my desk working files.. and if no one laughed at the magic lemur picture, im going to be very very VERY hurt.
Old Feb 22, 2011 | 07:55 AM
ZS14RR's Avatar
ZS14RR
Lol
Old Feb 22, 2011 | 07:59 AM
lgear080's Avatar
lgear080
i've experienced extremes of this - prob due to a 10.5" front wheel and 285/35 tire.
the sensation is intense and forceful. it'll literally pull the car left or right and require
immediate input.
didn't grasp this was a real, defined issue...
Old Feb 22, 2011 | 08:19 AM
winchman's Avatar
winchman
Thanks, Jennifer. You've added a new word to my vocabulary along with some useful info.
Old Feb 22, 2011 | 08:25 AM
bmccann101's Avatar
bmccann101
agreed.
"all vestiges of tramlining disappeared."
That is some pretty hardcore linguistic smack down happening here my lady.. i think ill change my facebook status to that sentence and see what kind of response i get. aaaaand its done.. status updated.. k ill be gone, sorry, it was just fun. hee hee.
Old Feb 22, 2011 | 08:38 AM
SSNOS's Avatar
SSNOS
The brakes are adding to the effects of bumpsteer/rollsteer/camber and toe gain. ALmost any car with a sport suspension has to deal with this to some degree.
350Z_Al
Oct 29, 2020 07:44 PM
wanderingstuden
Jan 28, 2016 07:03 PM
samansharif
Sep 25, 2015 12:31 PM
