Spacer for more aggressive look
Old Feb 27, 2011 | 10:33 PM
paulpoca2003's Avatar
paulpoca2003
Default Spacer for more aggressive look
Hey guys, I have 19X8.5+20 and 19X10+15 wheels right now and I'm trying to make it look more aggressive. After my noob calculation I think I should get 5mm spacer front and 10mm spacer rear? I don't wana scratch my fender all the time and I'm not going to have crazy negative camber. Just trying to make it look as aggressive as possible. Do you guys think it will work or 10mm all around? Or maybe 15mm?
Old Feb 27, 2011 | 10:39 PM
kemps's Avatar
kemps
25mm front and 15mm rear, I think
Old Feb 27, 2011 | 11:05 PM
User 42426's Avatar
User 42426
aren't the rears already pretty flush? Other than get, get 25mm for the front.
Old Feb 27, 2011 | 11:07 PM
paulpoca2003
I think thats too much....... I just found this offset calculator and I'm pretty sure I should go with 5mm front and 10mm rear. Btw how hard is it to install spacers w/o studs thats already in it?
Old Feb 27, 2011 | 11:23 PM
kemps's Avatar
kemps
no way, im 19x9.5 -3 front and 19x10.5 -8 in the rear and barely poke out
Old Feb 27, 2011 | 11:24 PM
mestupryan's Avatar
mestupryan
check the stickied thread on wheel spacers - its great. according to that thread, 5mm spacers are the biggest we can go on our stock studs, so you would either need longer studs or get some nice wheel spacer/adapters for the 10+mm
Old Feb 28, 2011 | 06:52 AM
scotts300's Avatar
scotts300
5mm max with the stock studs.
What tire sizes? It matters.
Agreed.
Old Feb 28, 2011 | 07:30 AM
350Z_Al's Avatar
350Z_Al
Agreed.
And that pic, he's lowered. That will suck the tires in quite a bit.
OP, In your situation I would do a 15mm front and a 10mm in the back. That would be mild.
5mm in the front isn't enough! I had 8.5 +20 front and added a 25mm spacer to it.
Old Feb 28, 2011 | 07:39 AM
vex008's Avatar
vex008
not sure what size spacer you would need but I have ichiba v2 on my fronts and project kics on my rears.
prefer the ichiba spacers to the kics.
just my .02
Old Feb 28, 2011 | 08:24 AM
Voboy's Avatar
Voboy
Front needs a bit more... 10mm to 15mm would be about right. The rear I would leave alone, or get rear camber arms if you are lowered and bring them back to around -1 degrees. If you still want to run spacers in the rear after that, that's up to you but I don't think there will be much of a gap by then.
Old Feb 28, 2011 | 09:07 AM
scotts300's Avatar
scotts300
A 9.5 +15 rear with a 275 tire is pretty aggressive for the average Joe. Given your comments about not fudging with fenders or negative camber, I'd try a slip-on 5mm and see how you like it. As I said, tire size does matter.
Again - tire size matters. For the street I run an 8.5 +10 with a 265 tire and a LOT of camber. There isn't more room to run more spacer - I've tried. As I said above, for the street, I run a 9.5 +15 rear with a 275. There may be room for a 5mm spacer, but no more.
Old Feb 28, 2011 | 10:47 AM
drivessidewayz's Avatar
drivessidewayz
Nvm, re-read it.
Old Feb 28, 2011 | 01:25 PM
Put your fingers between the tire and fender. How far do you want to move the tire? 10 mm? 20 mm? See that was not so difficult.
Old Feb 28, 2011 | 07:55 PM
kemps's Avatar
kemps
225/35 front, 245/35 rear
Old Feb 28, 2011 | 11:23 PM
SQBassHead's Avatar
SQBassHead
LMAO!!!!!!
FKN david lol
Op what tires are u running sober know if you want stretch and poke or fat tires
Old Mar 11, 2011 | 09:04 PM
Never mind. I thought this was important. Important enough to say “thanks” or simply reply.
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
