here we go again! WHEEL SPACERS
Old Mar 31, 2011 | 02:10 AM
Mcutali's Avatar
Mcutali
Question here we go again! WHEEL SPACERS
ok so got some ichiba 25mm spacers, now they are installed. car definetly feels like its loss power. what is everyone talking about with extended studs? my kit came with new studs on spacer, i slipped them over my oem studs bolted those down with the tiny lug nuts supplied, then applied hub ring and spacer, wheel and tightened. so i guess my question is should the oem studs be removed and replaced with longer? how would my rim clear with the studs hanging out of the front of the spacer?
Old Mar 31, 2011 | 03:04 AM
DavesZ#3's Avatar
DavesZ#3
Moved to proper forum
Read the FAQ sticky thread at the top of this forum
Old Mar 31, 2011 | 03:37 AM
NZMOWND's Avatar
NZMOWND
you install spacers and feel like you lost power???
Promise you that you didnt lose power but if you want to take into account the extra 10 pounds that you put on the car then it probably made it significantly slower and you should turbo it to gain your speed back...
Old Mar 31, 2011 | 03:41 AM
Mcutali's Avatar
Mcutali
not per say power but acceleration out of first. i just got tuned and my ride has been monster and now since its looking hot with the spacers and theyre on i drove to work today thinking "hmm this is sluggish".
its just time for jwt cams
Old Mar 31, 2011 | 03:47 AM
NZMOWND's Avatar
NZMOWND
Still...the extra weight wont cause it to feel sluggish...not nearly enough to notice...id have it checked out
Old Mar 31, 2011 | 03:58 AM
DavesZ#3's Avatar
DavesZ#3
Putting spacers on a car is just like adding heavier wheels. It increases the rotational inertia and that slows acceleration. I doubt you'd feel it but I guess it's possible if you added 10lbs to each wheel. It will certainly affect handling and ride quality as you have added significant unsprung weight.
Old Mar 31, 2011 | 04:00 AM
silvertouringz's Avatar
silvertouringz
i have these ichiba 25mm's and they suck so badly! 100+MPH and u get ur car shaking
Old Mar 31, 2011 | 04:24 AM
Barnabas's Avatar
Barnabas
National Z Club President
thats a huge spacer to put on the stock lugs!! I would get extended ARP lugs then put on slip on spacers, but thats just me.
Old Mar 31, 2011 | 05:02 AM
Z04's Avatar
Z04
take off the useless spacers. problem solved
Old Mar 31, 2011 | 05:32 AM
350Z_Al's Avatar
350Z_Al
The spacers have their own studs on them..... No need for extended studs.
Old Mar 31, 2011 | 06:16 AM
vex008's Avatar
vex008
have the 25mm ichiba v2 over the stock OEM studs and no problems at all.
no vibrations but still took off wheels and retighten/double checked everything 1 week after first time installed and no feeling sluggish in any gear.
Old Mar 31, 2011 | 06:23 AM
Arvin89's Avatar
Arvin89
Do you have hubcentric rings put in? Or maybe one of them broke?
Old Mar 31, 2011 | 06:27 AM
KornerCarver's Avatar
KornerCarver
Thinking the spacers probably add 10 lbs in total. I suspect each spacer is the neighborhood of 2 or 3 lbs.
Old Mar 31, 2011 | 07:25 AM
AngelsVQ's Avatar
AngelsVQ
seems like everyone is making this complicated....
*you do not need to buy extended studs with your spacers.
*you did not loose power.
*your wheels WILL fit because if you look at the back of your rim there are hollow areas there.
there.
Old Mar 31, 2011 | 08:00 AM
NZMOWND's Avatar
NZMOWND
I was being sarcastic fyi lol this is a dumb thing to think that wheel spacers cause you to lose power lol
Old Mar 31, 2011 | 10:59 AM
Mcutali's Avatar
Mcutali
Default re
all four spacers weigh 9lbs not 10lbs each.. i havent gone 100mph yet so i havent experienced the shaking, i did take the car out today and say its not as sluggish as i think. i got some other issues with wheel bearings right now to take care of. i am using stock studs, the ichiba slips over them and has its own studs, why would i need extended? they fit perfect, one guy said rid the spacers and problem solved, well yea then i have a dropped 350z with wheels tucked in, looks stupid and unfinished.
Old Mar 31, 2011 | 11:15 AM
lixam's Avatar
lixam
are you high?
Old Mar 31, 2011 | 11:38 AM
Nexx's Avatar
Nexx
ah oh..... you guys know whats coming.....
yo yo yo its Nexx with STANCENATION IN CONJUCTION WITH STANCEWORKS, REPRESENTING THE HELLAFLUSH NATION, here to remind you, that real offset isnt achieved with spacers!!! word dawg, yeeeeeeeaaaaaaaa boooooooooooiiii!!!!
Old Mar 31, 2011 | 11:42 AM
lixam's Avatar
lixam
im rocking 38 & 30 mm spacers
Old Mar 31, 2011 | 11:49 AM
BoomerZ33's Avatar
BoomerZ33
+1 that's exactly what i did and the car handles great.
