here we go again! WHEEL SPACERS
Old Mar 31, 2011 | 01:25 PM
silvertouringz's Avatar
silvertouringz
Originally Posted by Arvin89
Do you have hubcentric rings put in? Or maybe one of them broke?
yea bro i have...
Old Mar 31, 2011 | 08:43 PM
Mcutali's Avatar
Mcutali
Thumbs down re
Originally Posted by lixam
are you high?
Old Mar 31, 2011 | 08:54 PM
Barnabas's Avatar
Barnabas
National Z Club President
Originally Posted by al@phatrides
The spacers have their own studs on them..... No need for extended studs.
The point inst that the type of spacers NEEDS them its that that is allot of stress for the stock lugs when the spacer is longer then the stud. I have seen stock lugs break from allot less then a wheel hanging an inch past the end of them.
but I guess if you just want your wheels to look good and dont care about safety or functionality your fine stressing metal that isnt meant to hold that kind of stress
Old Apr 1, 2011 | 05:30 AM
350Z_Al's Avatar
350Z_Al
Strange, I had 15mm Project Kics spacers on my stock studs all last summer. Drove it hard, autocrossed it on a regular basis. It was perfectly functional and safe. No problems at all
Should wheel studs be replaced when changing to a wheel that has a more negative offset than stock?
Old Apr 1, 2011 | 05:52 AM
lixam's Avatar
lixam
i have 38mm and 30mm spacers on stock STUDS and running -4.7 ish rear camber and about -3.5 front camber..
no problems so far.
Old Apr 1, 2011 | 06:16 AM
Barnabas's Avatar
Barnabas
Personally I used to run 15mm spacers on my stock studs as well. But I upgraded to arp after seeing lugs break at an autox. A few of my lugs were stretched when I removed them as well.
I'm not saying its mandatory but when your spacers are wider then your studs are long... you can't honestly think that's safe to drive hard on. I beat on my car everytime it goes out. I'm not gonna risk losing a wheel. Buying arp studs + slip on spacers isn't much more then buying spacers with built in studs
Old Apr 1, 2011 | 06:17 AM
terrasmak's Avatar
no problems so far.
I'm sorry
Old Apr 1, 2011 | 06:27 AM
350Z_Al's Avatar
350Z_Al
You should probably invest in better lug nuts then. Doesn't sound like your studs are the problem, sounds like your lug nuts are.
Old Apr 1, 2011 | 06:32 AM
Barnabas's Avatar
Barnabas
Project kiks it def was not my lugs lol
Old Apr 1, 2011 | 07:00 AM
AngelsVQ's Avatar
AngelsVQ
I'm sorry
Rofl!
Old Apr 1, 2011 | 07:04 AM
350Z_Al's Avatar
350Z_Al
Read your last post, you just said you stretched your lugs......
Old Apr 1, 2011 | 07:06 AM
Toby-22's Avatar
Toby-22
wtf is this. You wont feel anything with a 25mm ichiba wheel spacer. THey weigh like 1lb each. its called placebo effect.
Old Apr 1, 2011 | 07:08 AM
AroundMyHorn's Avatar
AroundMyHorn
The only thing I'm feeling is vibration at 60 mph or above, very aggravating. Ichiba v2's FTMFL!
Old Apr 1, 2011 | 07:36 AM
MYN1SMO's Avatar
MYN1SMO
This should solve your power loss problems, and then some!
http://www.engineperformancechip.com...r-2-5-psi-p-16
Old Apr 1, 2011 | 10:29 AM
NZMOWND's Avatar
NZMOWND
this dude is dumb as shiet...idk what he was thinking posting this tho but this thread needs to be locked and used as an example under the "im a stupid fuggin idiot" thread...
on a side note i just installed spacers and now i think that might exhaust is louder...any idea why??
Obadabot
Jun 18, 2023 11:31 PM
