Wheels & Tires Wheels, Tires, Big Brakes, Coilovers, etc...
Z1 Hub Centric Wheel Spacers & Extended Studs
Old May 22, 2013 | 11:19 AM
  #121
Z1Motorsports's Avatar
Z1Motorsports
Messages and inquiries replied
Old Jun 3, 2013 | 05:42 AM
  #122
Z1Motorsports
CNC machined from billet aluminum, these wheel spacers are available in bolt on and slip on form and available in a large range of sizes; perfect for achieving the perfect stance.
Old Jun 10, 2013 | 06:32 AM
  #123
Z1Motorsports
Available in two styles (both are hubcentric!) and a large range of sizes (from 2.5mm to 30mm!), these wheel spacers let you customize your Z's stance to your exacting specifications.
Old Jun 13, 2013 | 05:55 AM
  #124
Z1Motorsports
Bolt-on or slip-on configurations available! In stock and ready to ship
Old Jun 14, 2013 | 05:39 AM
  #125
Z1Motorsports
Our 5mm Hub Centric Wheel Spacers remain flat to allow the hub center to protrude for centering of Hub Centric wheels whereas our 10mm, 15mm, and 20mm Hub Centric Wheel Spacers all have an extended hub portion to allow for centering of Hub Centric wheels.
Old Jun 17, 2013 | 05:26 AM
  #126
Z1Motorsports
Our Z1 Motorsports bolt-On Wheel Spacers are CNC Machined from Billet Aluminum and are perfect for achieving that flush look. Available in 20mm, 25mm, or 30mm, these spacers should suit any of your extreme wheel spacing needs.
Old Jun 19, 2013 | 06:14 AM
  #127
Z1Motorsports
Slip on spacers are hubcentric and available in 5mm increments: 5, 10, 15, 20 mm and are available with extended studs.
Old Jun 28, 2013 | 06:21 AM
  #128
Z1Motorsports
These Hub Centric Wheel Spacers with Extended Studs are CNC Machined from Billet Aluminum and are perfect for achieving that flush look. Available in 5mm, 10mm, 15mm, or 20mm, these spacers should suit any of your wheel spacing needs. If you require something in between the spacer sizes here, we sell 2.5mm Hub Centric Wheel Spacers which can be used in conjunction with these spacers and extended studs.
Whats Included:
(2) Hub Centric Aluminum Wheel Spacers (Your Choice of 5mm, 10mm, 15mm, or 20mm)
(10) Extended Wheel Studs (10mm longer than stock for 5mm and 10mm spacers, 20mm longer than stock for 15mm or 20mm spacers)
Optional ARP ~25mm Extended Studs
http://www.z1motorsports.com/350_g35...oducts_id=4215
Old Jul 8, 2013 | 06:17 AM
  #129
Z1Motorsports
PM replied
Old Jul 10, 2013 | 12:26 PM
  #130
Z1Motorsports
BUMP!!
Old Jul 16, 2013 | 06:36 AM
  #131
Z1Motorsports
BUMP!
Old Jul 23, 2013 | 01:29 PM
  #132
Z1Motorsports
Spacers in Stock!
Old Aug 2, 2013 | 08:47 AM
  #133
Z1Motorsports
Bump
Old Aug 12, 2013 | 07:16 AM
  #134
Z1Motorsports
New shipment in stock!
Old Aug 15, 2013 | 08:32 AM
  #135
Z1Motorsports
Bump
Old Sep 20, 2013 | 08:15 AM
  #136
Z1Motorsports
bump
Old Oct 18, 2013 | 08:24 AM
  #137
Z1Motorsports
Bump
Old Nov 1, 2013 | 01:19 PM
  #138
Z1Motorsports
bump
Old Nov 14, 2013 | 11:35 AM
  #139
Z1Motorsports
Old Dec 2, 2013 | 10:39 AM
  #140
Z1Motorsports
